Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
We have a whirlpool top loader (Gold ultimate care II quiet wash plus). After washing, clothes are stained with grease like spots. Do you have any idea what is causing this?
I am not an expert but I would guess it is your soap. perhaps try a different brand or maybe less.... I have not had this issue with mine but i did have the issue with my old washer and it was actually soap and not grease that caused the issues. I could be completely wrong, maybe you just need to run a cleaning cycle.
Posted on Jan 17, 2013
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II, Quiet Wash, Super
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Posted on Aug 13, 2009
SearsTechToo
  • 261 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
SOURCE: new Problem
remove drain pipe and make sure it is not blocked i had same problem And found money in the elbow of drain pipe blocking it up. when u r trying to turn by hand u are turning gearbox as well and is normally not easy to spin when they stop during a cycle
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
good luck
a very helpful rating is appreciated for answering ur query....
Posted on Aug 18, 2009
oldmanewtoys
  • 414 Answers
SOURCE: Why are clothing coming out with holes in them,
Bleach is #1 cause in most cases. However if your agitator has become use items may be getting under and tearing holes also.
Posted on Feb 26, 2010
honeymokey
  • 3113 Answers
SOURCE: on rinse cycle...cannot control water
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Posted on Apr 01, 2011
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water runs from under wash machine when running . It's a whirlpool ultimate care super capacty plus
If it is a top loader, check the seal under the top cover. It also could be a cracked hose from the pump
Nov 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpoole gold top loader stop working
Try pushing down on lid switch. common problem for these models.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
330 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
