Question about Mag Innovision LT561D PNP Monitor
Mag LT561 Lcd monitor
Hi I have no power and it makes a popping noise in the speakers i was wondering if someone knows were to buy parts for this monitor
  • hill dave Jul 10, 2007
    the board on the bottom right is the board that is bad and if anyone knows where to locate it please i would appreciate it
  • Mag Innovision Master
  • 12,061 Answers
Simply try replacing ALL the large Value Electrolytic Capacitors on that board, 1000uF, 470uF, 330uF, 220uF, they are "the big fat round blue things" marked with say 1000uF 16Volt or the like, get the EXACT same ones and replace them... this may indeed fix ya uint. Good luck.
Posted on Jul 24, 2007
SOURCE:
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Monitor is making clicking noise when powered up
The clicking sound you hear is from the power supply trying to power up. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Oct 17, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Power plug
I found a place where you can buy one. Here is the link and it will be available for the next 3 days. The cost is $15.99 + $7.99 Shipping.
Here is the link: http://cgi.ebay.com/New!-AC-Power-Adapter-for-MAG-innovision-LCD-LT573S-568_W0QQitemZ270439257439QQcmdZViewItemQQimsxZ20090807?IMSfp=TL090807154005r44
If you have any more questions, please let me know.
Aug 30, 2009 | Mag Innovision LT576s 15" Flat Panel LCD...
I need a power cord for a mag innovision lcd monitor
You can buy a power cord at any Lowes, Home Depot, Radio Shack or Best Buy. The power cord is not unique to the monitor.
Dec 26, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision LT765b 17 in. Flat Panel LCD Monitor
Hi...there,
Well, sure it fixable... but not so easy to find a AD board online. Only manufacturer carried this part... If you want you can contact them if they still have a refurbished parts laid around....
Jul 26, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor not working...sorta
I just changed my video card and after turning up my screen refresh rate (Hz) my monitor started doing the same thing. Monitor worked great for a long time but now its done! The only thing I can think of is that it has to have 60Hz, turn it up for gaming and its too sensitive to frequency. By the way, mine will turn on after a few power cycles.
Dec 01, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
Oct 07, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Monitor LT982s model900p
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Oct 02, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Open Questions:
See all Mag Innovision LT561D PNP Monitor Questions
Computers & Internet Logo
82 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
