Question about Brother MFC Office Equipment & Supplies
I need help setting up a printer.
No manal i need help sitting up a brothers 4 in one printer MFC-825 DW
    Problem Solver:
  • 8 Answers
Well setting up most printers are almost alike. will it be hooked up to a laptop or a desk computer?
Posted on Jan 13, 2013
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
MacD7
  • 67 Answers
SOURCE: Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Posted on Apr 25, 2010
Samyfam
  • 378 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
Can a Brother MFC-470 DW used with this tablet it is wireless?
Yes. You can print from your tablet but first you have to make sure that your printer is connected wireless to your network, then on your tablet when you go to print something, choose the network printer.
Jan 11, 2016 | Tablets & eReaders
Fixya won't let me add a product, even though it is on the list!
refreshing the page and try again. It always is the best solution. I hope it works.
Jun 28, 2015 | Brother MFC-J475DW All-in-One Inkjet...
Maintenance mode in brother mfc 5910 dw
Robbin, your anwer is wrong, those kind of codes are usually not provided in the owners manual. I had a bad inyector obstruction problem on another Brother and the support provided me a maintenance code to access a hidden menu with "heavy" cleaning options that don't appear in the manual.
Feb 18, 2013 | Brother MFC-J5910DW Color Inkjet...
Error Message- Ink Absorver Full-MFC-J415W"
Sir/Madam
Your Brother Printer Machine automatically cleans after clearing a printer jam.And Brother Printer Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
To solve the problem:
The ink absorbed box or flushing box will need to be replaced.
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For Brother Printer Support
Dec 20, 2012 | Brother Ink for Mfc J415w Printer
How do I put my brother MFC 8870 DW into maintenance mode
That's where the owners manual comes in handy...If you don't have one, you should be able to download one from their website...Good Luck.
Oct 15, 2012 | Brother Multi-Function Center MFC-8870DW...
Brother mfc 8440
menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Fax
This si str8 from the manual! The Ring Delay sets the number of times the MFC rings before it answers in Fax Only or Fax/Tel mode. If you have extension phones on the same line as the MFC or subscribe to the telephone company?s Distinctive Ring service, keep the Ring Delay setting of 4. 1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 1. 3 Press ▲ or ▼ to select how many times the line rings before the MFC answers (00, 01, 02, 03 or 04). Press Menu/Set. (If you select 00, the line won?t ring at all.) 4 Press Stop/Exit. Full Manual URL http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf Hope this helps! Regards, Babb
Apr 28, 2007 | Brother MFC 420CN All-In-One InkJet...
66 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
