Question about Frigidaire FGX831F Top Load Stacked Washer / Dryer
Frigidaire model FLXE52RB58 dryer not working
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: Frigidaire FLXE52RB58...washer filled, but did
first thing this is the entire schematic for your machine http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLXE52RBS8/1428/0152000?searchedModel=FLXE52RB58&blt=11 so the dryer still works correct? first thing would be the lid switch to check on the washer if the washer is not working the lid switch i think is located at part number 50 on this diagram unfortunatley this diagram is a bit fuzzy so you will have to double check on this http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fY2705246-00005.png if you have any questions message me back you should be able to hear the lid switch click as you open and close the lid you can also take a electrical wire and strip both ends and then go to the connector that the lid switch plugs into and connect the electircal wire now that you have stripped both ends it becomes a jumper wire and connect between points 1,3 on the switch this bypasses the switch itself and can be used in this manor as a temporary repair until you replace the switch itself note that if you do open the lid after you have done this the unit will still spin and agitate not like before when it would stop be extra careful if you jump this switch around small children and if you have any further questions message me back and please also message me back with your finds if the lid switch checks out to be in proper working order then message me back this information as well this is where you would start troubleshooting your unit and is usually one of the first probelm areas with the machineThanks Rick
Posted on Apr 10, 2011
Frigidaire Dryer Model # GLER331AS2 wiring diagram
Hello Anonymous, thank you for your post!
I have successfully located the Wiring Diagram of your Frigidaire dryer, GLER331AS2. I hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Best regards - Z
Apr 06, 2014 | Frigidaire Dryers
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire FGX831F Top Load Stacked Washer / Dryer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
