Question about Sharp 25K-S100 TV
Sharp 25K-S100 TV specifications - Sharp 25K-S100 TV
4 Suggested Answers
  • 71 Answers
SOURCE: Sharp Model 25N-S100 - black triangle on screen
turn off cc/closed caption
Posted on May 03, 2008
SOURCE: reprogramming my sharp 25k-s100 with universal remote
Try 173
Posted on May 07, 2009
  • 4234 Answers
SOURCE: Does my sharp tv model 25k-m180 have a digital
This particular model is old enough to have an analog tuner (NTSC) rather than a digital one (ATSC). In order to receive the new over the air signals which are digital a converter is required. Not all CRT based sets are analog only, but this one is. No external converter is required if you have satellite or cable.
Dan
Posted on Apr 27, 2010
Yoke has been smoking
Hello
There is a short between winding inside its horizontal section, and cannot be rectified or repaired. The ony remedy is to replace it with a same type and number. You have to do a lot of adjustments and positioning to get a clear screen without any colour patches. Ok.
Dec 23, 2010 | Sharp 25K-S100 TV
Cant sync my universal control what the code
Hello
You just try these codes with your tv. One aboung them will wake up your TV.
NB: Switch OFF and switch ON the Tv each time before a code is tested.
Three digit universal remote codes for Sharp are:-
027 /224 /324 /338 /631/ 637 /737 /825/004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp TV are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 22, 2010 | Sharp 25K-S100 TV
I have lost the remote how do I access the menue
Buy the Sony rm-v210 universal it will access the menu guaranteed
Dec 19, 2010 | Sharp 25K-S100 TV
Hi i have Sharp 25K-S100. how can i know whether it is HDTV or not. I dont have any manual. and I just want to buy one cable to connect my laptop to TV. Please adivse
Howdy, if it has a S-video input ( the round one with the pinholes) and your PC has S-video, then that will deal with the video. Sound runs seperately through either the red and white or the headphone jack at the tv end to the audio out port on the PC. Your TV does not likely have a VGA input, but if it does, then it is the same as the VGA standard monitor output on your PC. As yours is an older model, it may be tricky to get a decent picture from your PC.
Best regards, Farmerbear at FixYa.com
Sep 15, 2010 | Sharp 25K-S100 TV
My tv makes a high pitch noise and is getting longer and more frequent, can you suggest a solution. thanks
The squeel you hear is created by a part wich is vibrating (resonating) at the horizontal Frequency - approx. 15KHz - To stop the noise you have to locate which part is vibrating and either replace it or isolate its vibration - The parts which commonly vibrate are theFlyback transformer or drive/pincussion transformer or the yoke. Each of these parts have hazardous voltage and High Voltage present so care should be taken when working around these areas.
Sep 20, 2009 | Sharp 25K-S100 TV
Tvproblem
The Sharp part number is: RTRNF0019MEZZ, but I list this as no longer available. You can check with local service shops and see if they have one around. I can not find any supplier with that part any longer.
Dan
May 09, 2009 | Sharp 25K-M100 25" TV
Digital or Not
The Sharp 25R-S100 TV is a standard NTSC TV with a 181-channel PLL tuning system....which means that it is not digital.
Jan 24, 2008 | Sharp 25R-S100 25" TV
Sharp 25K-S100 TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
