Question about Tablets & eReaders
Tablet wont come on,have tried re setting to factory settings but nothing works,its less then a month old.
Tablet just flashes on and off,wont re set to factory settings.
  • kellie smith Jan 13, 2013
    have manual,followed instructions but didnt work
    its a binatone kidz -star tablet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tablets & eR... Master
  • 102,366 Answers
What make and model tablet?
Posted on Jan 13, 2013
  • 3 Answers
SOURCE: how do you reset to factory settings?
Many times the original paper work that came with your devise, will give suggestions for this. You could try calling or visiting your local Best buy or similar store to see if they may be able to help. Otherwise, try to Google the manufactures website for the specifics. Hope this helps. Good luck.
Posted on Feb 04, 2012
  • 37 Answers
SOURCE: My samsung Tablet is 10 wks old, a month after I
You should return the device. It sounds like a problem with the hardware or the software. A good many rooted versions of android exp. these same problems also.
Posted on Mar 21, 2011
Testimonial: "wow that was quick thanks."
edgedev
  • 81 Answers
SOURCE: How to reset Pandigital 7 in. Planet Tablet to
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Posted on Oct 17, 2011
TechyDrood
  • 2072 Answers
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
Posted on Nov 27, 2012
turnergreen9
  • 11 Answers
SOURCE: my supernova tablet is not working it wont hold a charge,tried charging through my laptop and its not charging its less than 3 months old and the store wont take it back!!!!!!...
It must have got wet, or when you first had it did you let it die all the way without charging?
Posted on Dec 31, 2012
Can't load fb on my tablet could this morning and now it wont
mine did this, i tried everything i thought. finally one of the geek squad guys told me to reboot my tablet. under settings you can reset everything back to factory settings. i uninstalled Facebook reinstalled it. but after i reset it back to factory setting it works like brand new. fast as ever. i lost all my data i had, so you may want to send it to another devise but this worked great for me. hope it helps.
Jan 13, 2016 | RCA CA 7" Tablet with 4GB eory 28458515
My zeepad 7inch wont turn on wifi. I tried restarting it i factory reset it. nothing works. I go to settings and wifi is off i try to switch it on and it dont work? Any thoughts?
Could you earlier use Wifi?
Do you have WiFi available?
If can't use WiFi, having signal it's network adapter is defective and you should claim your warranty.. If old, should seek for repair
Jun 23, 2015 | Tablets & eReaders
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
Mar 07, 2015 | ASUS ME176CX-A1-WH Memo Pad 7 7IN 16GB...
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
Downloaded files on galaxy tablet 10.1 does not open, help?
you dont mention what types of files you downloaded but, I'll try some basics. if your security settings require downloads to be from google play or the samsung app store, you have to reconfigure your settings. Also, the downloads must be android compatible. if they need flash, you will need a browser with flash built in like puffin as flash stand alones are useless. finally, you deleted files to make room? you might need to be certain you didn't delete any essential files or files attached to factory installed programs. without knowing what downloads you are trying or where they were downloaded from. I can offer nothing further. good luck
Dec 13, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
My Galaxy Tab 3 7.0 will not turn on. Is there a way to reset it?
Press the power button and the "up" volume to initiate a soft reset. If it turns on and you get access to your operating system then enter the setting a do a hard reset to re-install to the factory settings. If any of these don't work then it might be time to use the warranty and have it fixed.
Aug 17, 2014 | Tablets & eReaders
How to reset a pandigital 7270FW Tablet
Maybe this video might help
https://www.youtube.com/watch?v=2yvBRURe-3I
or this
http://www.fixya.com/support/t10680045-reset_pandigital_planet_tablet
There should be a small hole to stick a paper clip into to do a reset,press it gently til it reboots
Alos can do it following this advice
Jun 14, 2014 | PANDIGITAL 7270FW Tablet
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
How to reset Pandigital 7 in. Planet Tablet to factory settings?
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
70 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
