Question about Gateway MX3215 Notebook
DC jack issues
Ok so this is what is written on the part in question and I am trying to figure out what the actual part number is so I can get a replacement, and some directions on where to find said replacement part would be outstanding
Plotech 6 94v-0 \
11107-4202 \ written on the actual mini circuit board
051031-65 <---- written on actual silver plugin the cord plugs into
I know for fact this is the defective part I jerry rigged the wires into the power cord and was able to power up the laptop. yes I know not smart, I like to live dangerously.
the Laptop is a Gateway MX 3215 any information would be greatly appreciated. my girlfriend would be very pleased with me and I could use the brownie points :)
many thanks in advance for your help.
  • nrossi Mar 13, 2009
    hey dburda-- i need the same replacement part for my old gateway laptop and am having trouble finding it. you have any luck?
  • caseytwichy9 Mar 30, 2009
    i got the same part in my laptop. turns out the whole pcd fried out. and plotech sayes they never made the product. ah if anyone can finda a pile of them riged up and ready to go i would love you forever
  • 41 Answers
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Plugged in not charging
There could be several things wrong. You could have a broken DC jack on your motherboard. To prove this, wiggle the DC jack with the adapter plugged in. If the charging light comes on when you wiggle the jack, then your jack is broken. You could also have a defective AC adapter.
Jan 06, 2013 | Toshiba Satellite C655-S5125
Turns off after few seconds with batery or with the power cord only. never turn on the monitor, just fans sound for 5 seconds and stop rotate and the start blue botton light remains on.
Check the battery is charged first and that power is getting to the laptop by the DC Jack. You can test this by setting a multimeter to 20V DC and touching one probe to the inner part of the DC jack and the other probe to the Outer (earth) of the DC jack (red to inner black to outer). I'm assuming the fuse in the plug of the adaptor is ok...
If there is power getting to the DC jack, check the connection to the DC jack socket on the motherboard, if it feels sloppy or loose, this is where the problem may be.
If the fit is tight and the AC adaptor is supplying power, you could have a ram issue. Romove each ram module in turn and try to see if the laptop boots then, if one stops it booting, it needs replaced.
Failing this, you could have a fault on the motherboard which will need technical investigation
Jan 02, 2011 | Computers & Internet
No lites no power will not boot up ac power supply test ok
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 05, 2010 | Toshiba Satellite M205-S4806 Notebook
How do i replaced the charger socket in my l300d toshiba laptop
I have come across this issue in a number of Toshiba laptops recently. The DC jack assembly (which includes a wiring harness and the DC jack) actually breaks away from the bottom laptop housing. What I have done is to glue the jack back in place using a hot glue gun. You need to be careful and observe how the right speaker (located on the top housing) is situated. Be liberal on the glue and make sure the jack is encased in the glue. I have not had any units returned after this was done.
Good luck
May 15, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Compaq Presario X1000 Power Issue
Two things... put your hand on the bottom of it.... is it really hot and second any chance of trying another power cord on that ?. I believe you mentioned you tried that cord on another computer. perhaps use the other cord on yours to test it .
Aug 28, 2008 | Compaq Presario X1000 Notebook
Dc jack
if you can't match the model number on ebay just open and take a look at the dc jack and match to the pics on ebay.
its the best place to get the parts at a decent price.
Apr 28, 2008 | Computers & Internet
Acer DC Power Jack
well..actually, it's installed on the motherboard..you'd need to strip the whole unit open, and then figure out how to desolder it from both top and bottom layers of the board..loads of potential issues arise on that.
Mar 23, 2008 | Computers & Internet
Gateway MX3215 Notebook Logo
1,673 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
