Question about Canon imageCLASS MF8080CW - 12 PPM Flatbed Wireless Network Color Laser Printer, Multifunction Fax Machine, 5119B001AA, 5119B001, MF-8080CW, MF 8080CW, MF8080-CW, MF8080C-W, M-F8080CW, MF8080 CW
How do i close the cover of canon mf 8080c - Canon imageCLASS MF8080CW - 12 PPM Flatbed Wireless Network Color Laser Printer, Multifunction Fax Machine, 5119B001AA, 5119B001, MF-8080CW, MF 8080CW, MF8080-CW, MF8080C-W, M-F8080CW, MF8080 CW
Camera takes blurry pictures up close and sharper ones from afar. Camera will not focus on specific object either.
There is a "close focus" limit, depending on your lens. The standard "kit lens" won't focus closer than about 2 feet away. Check that the switch on the lens is set to "AF" not "MF" "MF" means, "manual focus".
When you lightly press the shutter button, the viewfinder should blink with little dots/squares indicating what it focused on, and beep. If it doesn't, and you are set for "AF", then your camera needs repair.
May 10, 2015 | Canon EOS 600D Rebel T3i Digital Camera
My camera will take a photo in MF but not AF
And you are sure the AF MF switch on the lens is set to AF?
If so, check the contacts on the lens and in the camera. They should be clean and shiny and have on dent. Only clean with a dry cloth and cotton swab. Never use anything sharp in or close to a camera or lens.
Oct 10, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Replacing a lens af/mf switch
It's an almost impossible task without taking apart the lens and I don't recommend that. Lots of hidden screws and things that must fit together perfectly. If it's just the switch cover you might replace ti successfully but if it's the actually switch you'd be better off sending it in to a repair shop or Canon.
Jul 11, 2014 | Canon Cameras
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
I lost my prienter cd for canon mf 4370 all inone wireless prienter
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Sep 23, 2012 | Canon MF, Print, Scan, Copy, Fax...
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf 5770 problem : opening the mf toolbox 4.9, the twain driver will not be shown, programm quits. running the setup utility of mf tool box again, it works, until system reboot, then the same...
I have the same problem. You can't use Canon Toolbox 4.9x. It does not work. You will have to download and intall the x64 driver only from the Canon website for the MF5770.
Unpack the x64 driver and install it.
Go to the Start-menu and click on Units and Printers. Right-click with your mouse when hovering over the printer, then choose scan, fax or print.
We can only hope that Canon will solve the problem in the future, most likely not since MF5770 is an older Multifunction-machine.
Jan 05, 2010 | Canon imageCLASS MF5770 All-In-One Laser...
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imageCLASS MF8080CW - 12 PPM Flatbed Wireless Network Color Laser Printer, Multifunction Fax Machine, 5119B001AA, 5119B001, MF-8080CW, MF 8080CW, MF8080-CW, MF8080C-W, M-F8080CW, MF8080 CW Logo
44 people viewed this question
old marine
old marine
