Question about Kenmore Refrigerators
Put ice maker bin back together kenmore 795.71053.010
  • 864 Answers
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
Posted on May 29, 2009
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Posted on Jul 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
SOURCE: know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
Posted on Nov 06, 2009
  • 71 Answers
SOURCE: water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Posted on Apr 01, 2010
What causes ice maker malfunction?
you could try cleaning the ice bin first of all the accumulated ice cubes that are all sticking together at the discharge side of the bin. thanks.
Mar 04, 2016 | Kenmore Refrigerators
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into repairclinic.com and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
Kenmore coldspot model 10657282791 ice maker dispenser crusher frozen
When you say "frozen" do ya mean that all the ice in the storage bin is one huge block of ice??
if yes all the ice is frozen together,that is caused by a malfunctioning water inlet valve that is not fully closing yet stays opena wee bit allowing water to seep into the storage bin and freezing all the ice together. To repair that the water inlet valve would need to be replaced. Its part number 2188542 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Refrigerators
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Know how to put the ice bin latch and spring back together
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
