Question about Brother XL-2600I
Thread is catching when picking up the bobbin thread
  • Brother Master
  • 1,564 Answers
What do you mean Catching. It's supposed to catch the bobbin thread... is it getting caught somewhere below?
Posted on Jan 14, 2013
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
SOURCE: brother ls2125 bobbin not picking up thread
you have the wrong size bobbin in ,its to high over the bobbin case causing it to rap around the bobbin.
Posted on Feb 10, 2009
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
  • 78 Answers
SOURCE: Needle will not pick up thread from bobbin on a Brother's machine
This is going to sound silly but its one of the first things I check for... make sure that the needle is in correctly make sure that the flat side is towards the back as you place it in the needle clamp. better yet take the needled out all together and put a new one in just to be sure that it isnt bend
Posted on May 31, 2010
Needle will not pick up bottom thread
Try a brand new needle. Verify it is installed correctly.
Remove the bobbin. Check that the bobbin is turning the correct direction and the thread is threaded correctly in the bobbin case. Reinstall the bobbin case and make sure that it latches.
Retest your machine. Manually turn the handwheel and watch the needle descend and see if the thread picks up the bobbin thread. If not, then the machine may have a timing issue. Take it for service.
Nov 01, 2016 | Sewing Machines
My thread is not catching with bobbin thread
Be sure to use a brand new needle. A bent/damaged needle may not connect with the bobbin thread.
If it still does not pick up the bobbin thread, your machine most likely has a timing issue (the needle arrives at the wrong time to intercept the bobbin thread). There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Wont pick up
Do this by turning the wheel by hand. The bobbin thread will make a small loop on the way up. Move something thin from front to back, catching the top thread under the needle and the bobbin loop thread will come out. Move both threads towards the back and go!
Jul 09, 2013 | Sewing Machines
Model PE-180 not picking up bobbin thread
Possible that the shuttle settings are not correct. remove the bobbin and thread it once again. reset it back on the catch and see if the thread is caught up. follow the directions once again and make sure the thread is freely moving within the bobbin.
Dec 07, 2011 | Brother Sewing Machines
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Brother XL-2600I Logo
67 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
