Question about Frigidaire GLTF1670A Front Load Washer
Door is locked, clean clothes inside
The door will not open, so I can put clean clothes in dryer
  • Official Brand Answer
  • 4,342 Answers
Hi tdudley770 - From what you have described the dryer may possibly have a communication problem with the control board, defective cord/wiring, or faulty door lock assembly. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, I suggest contacting a professional to accurately diagnose the unit and move forward accurately.
Posted on Jan 15, 2013
Master_Tech
  • 770 Answers
SOURCE: Door Lock
unplug the unit for 2 min then back in it should reset
Posted on May 11, 2008
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
  • 113 Answers
SOURCE: Electric clothes dryer will not turn on
Check in the upper corner of the dryer when you open it. There should be a slot where a little tab sticks out. This is the door switch. The tab should stick out about 3/4 of an inch. Is it broken? Dave www.washermd.com
Posted on Dec 17, 2008
BNewberry
  • 93 Answers
SOURCE: Door lock doesn't release automatically; clothes still very wet
You need the Factory Repair Manual for your Affinity Washer. There is alot that can go wrong with these machines and you will need to run the washer through its diagnostics.
Here is a Link where you can Download the Affinity Washer Repair Manual
Thanks
Posted on Jan 09, 2009
richroth
  • 9472 Answers
SOURCE: When you open the washer door a musty smell is
Here is a product that may help you.
Posted on Dec 01, 2010
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
Maytag Dryer drum not turning properly after cleaning
Make sure the drum belt is positioned properly. You may have disturbed it when you removed the front door panel. It should be a tight fit on the drum. You should see the wear pattern on the drum where the belt was. Check the condition of the belt and make sure it's not cracked or stretched and slipping. Did you disconnect any wires when you opened it? Double check that you didn't rehook the wires wrong and make sure the door sensor switch is in proper position. Hope that helps.
May 14, 2010 | Maytag Dryers
I put a load of clothes in my bosh nexxt 300 washer, went out to the store and such come home to put the clothes in the dryer, the door is locked, no lights on the washer. The washer is plugged in and plug...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Apr 24, 2010 | Bosch Nexxt 300 Series WFMC2201UC
My dryer is destroying my clothes,
There is a gap between the lip of the drum, and the dryer housing. Usually the gap is not large enough for clothes to get caught up..
I think the drum should be removed, and the drum bearings checked for excessive wear. This can cause it. There are like 6 rubbing blocks at the front, that the lip of the dryer runs on. This is what I mean by bearings. There will also be a single drum bearing at the back of the drum, check this also for wear or damage.
Hope this helps.
May 06, 2009 | Frigidaire Electric Dryer
GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Apr 26, 2009 | GE Washing Machines
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a Splendide 2000 s vented washer and dryer. I started a load and there was water leaking all over my floor from the washer, so I immediately turned it off. Now I'm trying to get those clothes out...
Unplug it. Door latch has thermal delay. Unplug, let cool 3 minutes, open door.
After door is open, you can kill the delay: with door open remove rubber boot to access gap between door & drum, remove door catch from cabinet, glue, break or unwire delay parts & replace all. Do this with safety glasses, the spring holding rubber boot can be a bit jumpy.
Your leak I know nothing of.
Jan 26, 2009 | Splendide 2100 Vented Washer-Dryer
Frigidaire GLTF1670A Front Load Washer Logo
197 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
