How to factory reset on onkyo 520
I'm getting no sound from speakers. How can I factory reset to solve problem, before taking to shop.
    Problem Solver:
  • 17 Answers
To reset theHT-R520 to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "Clear" will appear on the display and theHT-R520 will enter Standby mode.
Posted on Jan 16, 2013
  • 50 Answers
SOURCE: I have just bought a
Depending on the amplifier, it might not provide enough power (in Watts) to the speakers. If the speakers require more power, it won't be as loud.
Posted on Mar 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: Intermitting sound problems on Onkyo SR-705
Does it only happen when its being stressed (played really loud)? Is it hot? If so, is it well ventilated and away from other heat sources?
Somewhere in here is the answer.
"The AV receiver turns off as soon as it’s turned
on
• The amp protection circuit has been activated.
Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources,
and leave the AV receiver with its power cord disconnected
for 1 hour. After that, reconnect the power cord
and set the volume to maximum. If the AV receiver
stays on, set the volume to minimum, disconnect the
power cord, and reconnect your speakers and input
sources. If the AV receiver turns off when you set the
volume to maximum, disconnect the power cord, and
contact your Onkyo dealer."
That last sentence is misleading. I don't think they actually want you to play an active signal at MAXimum as a test. I think they mean with all sources attached and an idle one selected, like CD, crank the volume knob. If the amp is not in Protection mode you should always be able to detect some hiss up close.
For another thing, if it shuts down only with speakers attached the problem could be outbound at one or more of the speakers. I would isolate that piece somewhat before throwing my hands up and calling Onkyo. Make sure that the speaker cables are not shorting. Disconnect certain speakers and try it again until you figure out which one(s) are involved. Then it could be the speakers.
Posted on Apr 24, 2009
  • 478 Answers
SOURCE: Onkyo 501 Onkyo Receiver no sound out of right
if you are good at tinkering then you can pulol the top of the receiver and check the fuses on the board to make sure that they did not blow if not then it would be wise to take it to a repair shop to have your receiver checked out and serviced
Posted on Dec 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: I HAVE A ONKYO TX-910
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Posted on Apr 09, 2011
dunnbiker
  • 8546 Answers
SOURCE: i have an Onkyo ht-520 all of a suddeen it
That depends what's really wrong.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 29, 2011
Onyko TX-NR828 - no sound.
Hi, hope you tried to checked wires for short,speakers for short if its ok,factory reset again ,and then try Firmware update ,if it dont help contact your nearest Onkyo dealer :)
Oct 04, 2014 | Onkyo TX-NR828 7.2-Channel Network A/V...
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
No sound from back channels of my dtr-7 stereo receiver
Do a Factory reset. it's most likely a speaker setting issue. press VCR and wille holding it press the Standby button. once you see clear on the screen it is done. try it now!
Nov 09, 2011 | Onkyo DTR7 Receiver
I have an Onkyo ht-520 all of a suddeen it won't turn on. Can this be fixed without a repair shop
Apr 29, 2011 | Onkyo Audio Players & Recorders
My onkyo tx-ds575x lost power in a storm and now I get no audio from it. The sony bravia tv has sound but the onkyo won't send it to the speakers.
Please reset Onkyo receiver that will solve noisy sound problem, to reset the receiver, press and hold Video-1 button on unit and press Speaker-A button. Display will show *Clear* that means receiver has been restore on default settings, turn it On and check sound.
Hope this will help.
Thanks.
Apr 06, 2011 | Onkyo Audio Players & Recorders
I have an Onkyo TX-SR507. I just hooked it up
Hello Katieandjona,
My first & second
guesses would be monitor & head-set modes...
(possibly Zone 2 activated)
ELSE...
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/ STANDBY] button (see page 93).
Manual... page 5
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr507_577_manual_e.pdf
Hope this helps
Aug 26, 2017 | Onkyo Tx-sr507 A/V Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
Onkyo A-RV401 amp is not sending any sound to the speakers.
The protection circuit is self resetting, it operates only when there is a fault condition in the amp. there is most probably a failure in the output stages of the amp causing a dc offset condition in the speaker output. The protection cct operates to prevent damage to your speakers. It may be difficult to offer a solution to you for this, it gets a bit complex to fix from here...you may have dry solder joint problems in the output stages, or more likely, failed output components. if you have a transistor checker(ohms meter), then you may be able to determine if any output transistors have failed, I recommend taking the amp to a good HiFi guy for repair. Many (including myself) often replace the all transistors to the last 2 stages when outputs fail. assures reliability in the future to repair this way, but the cost goes up a bit also. expect at least $120 to repair is it is a failed output stage.
Jan 03, 2008 | Audio Players & Recorders
223 people viewed this question
 Grubhead
Grubhead
