Question about Juki DDL-8300
Wont pick up bobbin thread when i start sewing
I've just got an old juki 555 5 and am trying to get it going properly.  when i start sewing it won't pick up the thread underneath.  any help here would be fabulous!
  • Elke Ricks Jan 23, 2009
    ok, its picking up the bottom thread now but it is not sewing stitches nothing is linking together. and it seems its only cutting the bottom thread and not the top one>..??
    thank you i thought that might be the case
  • 378 Answers
After readind the comments it indicates that the problem of not sewing is because of the needle positioning and if after the new needle it still does not help.then its definately the timing problem that needs to repaired and checked by a technician.accurate timing of the needle and base clap mathing results in proper stitching or else it wont stitch.if timing problem is sorted by a tech it will be fine.nothing much to worry.thanks and do rate the solution.
Posted on Jan 23, 2009
    Brigadier General:
  • 8,619 Answers
Is the bobbin case pushed all the way in?
The upper thread could be tangled.
Remove the thread completely from the machine.
The correct size spool cap should be used for the size of the thread spool.
Re-thread the machine according to the directions in the manual.
You probably need to insert a new needle.
  • Rylee Smith
    Rylee Smith Jan 23, 2009
    Is your needle up too high or down too low in the needle holder? Try lowering it a little and see if that helps. And as mentioned before use a scrap of material to test it out.
    Make sure the flat part of the needle rests on the flat part of the holder.
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
My Juki LU-563 stopped picking up the bobbin thread, changed needle, took out bobbincase to look for thread, none, still won't sew because of bobbin thread not being picked up.
If you've properly installed a brand new needle that is correct for the machine, threaded it correctly, checked that the bobbin is installed correctly and the bobbin tension threaded properly, most likely the machine is out of time. In other words, the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin. (You can open the bobbin area, hand rotate the handwheel and watch how and where the needle moves in relation to the bobbin to see where and why it is not connecting.) You can search the internet for web sites and videos that discuss machine timing or you can take it for service.
Nov 09, 2016 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Juki, DNU-1541S: thread was not picking up the bobbin thread. The hook shaft is not moving... After trying to move the needle in a reverse motion... Now the hand wheel will not move it is frozen in place.
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
Sep 09, 2012 | Juki DNU-1541 Mechanical Sewing Machine
My Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Jan 23, 2009 | Juki DDL-8300
Juki DDL-8300 Logo
137 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
