Question about Fisher Paykel Fisher & Paykel AquaSmart WL42T26DW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 7 Wash Cycles, Load Sensing, Dual Washing Modes, 3 Dispensers, Auto-lint Disposal, Smart Drive System and LED Control Panel
WL42T26DW196178-A leaks near bottom when filling or running
  • 44 Answers
Bearing seals shot
Posted on Nov 13, 2013
Water leaks out the bottom through through the clutch when filled and running
There are gaskets and shaft seals that can leak. Not an easy task. On my GE washer, I had pinhole leaks near the transmission mounting flange. I used JB Weld epoxy and sheet metal screws to seal the leaks. and of course changed the gasket. That was 8-9years ago. So my investment in time and transmission paid off. A bright light under the clutch and a dark room may show what's leaking. you may be able to temporarily seal with a window caulk from the top or bottom Or a bathtub waterproof sealant. If it's the rubber gasket, a rubberized sealant "may" help. I guess it could also be the pump. I use paper towels tied around things like drain pipes to find leaks, or make sure my work is not leaking.
Mar 12, 2015 | Maytag Centennial MVWC6ESWW 4.0 cu. ft....
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
Losing coolant with no visible leaks 2005 jeep liberty engine 3.7
Did you listen to the radiator too see if it gurgles when filling? When filling the gurgling tells you there are no air or coolant leaks in the engine much the same as an upside down soda bottle gurgles when turned upside down. Also look in the radiator too see if bubbles are coming from the bottom of the radiator while running at normal operating temperature with the cap off.? If you see bubbles coming from the bottom, you have a leaking head gasket. This can and will happen without the coolant leaking into oil, and without oil leaking into coolant. The gasket leaks right near the cylinder and sucks the coolant into the cylinder on the intake stroke, and blows it back into the radiator on compression stroke. This is why the coolant bubbles up from the bottom. The coolant that gets sucked in gets vaporized and comes out the exhaust. Loosing coolant ?? This is where it is going if no leaks under or around around the vehicle.Good luck I hope this solves your problem. Please post a solved comment on fixya, so I receive credit for the solve.
May 01, 2014 | 2001 Honda CR-V
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
2002 Tahoe gas leak on top of tank
The top where the pump goes in is could be leaking. Have it checked ASAP, a gas fire is a dangerous thing.
Jan 28, 2010 | 1998 GMC Safari
1998 cadillac catera anti-freeze leak
First things first don't use Dexcool.
It would happen only once in a while likely because the overflow bottle doesn't always fill to the point of where the leak is located. It would be very easy to unbolt the bottle and fill it with water to find the leak and patch it up.
Jun 19, 2009 | 1998 Cadillac Catera
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Fisher Paykel Fisher & Paykel AquaSmart WL42T26DW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 7 Wash Cycles, Load Sensing, Dual Washing Modes, 3 Dispensers, Auto-lint Disposal, Smart Drive System and LED Control Panel Logo
121 people viewed this question
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Lawrence Oravetz
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
