Question about Aiwa CDC-X217R CD Player
Help I need a Wire diagram of the Aiwa Cdc x217r Cd Player
  • 41 Answers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Aiwa cdc-x317 will not eject cd. How to eject cd from Aiwa cdc-x317?
Somewhere on the front of deck there should be a small pinhole just big enough to fit the tip of a pen push it in either pen or Sharp object. It should force it out.
Sep 11, 2011 | Aiwa CDC-X317 CD Player
What color wires go where
To find out what your factory wires on your vehicle are, go to installer.com then click on the tab, cables and wires, select your vehicle.
What I do is go to walmart, kmart, target or similar, and get the $5 connector.. It wires to cd player and just plugs into the factory plugins.
Cd player wiring-
Yellow - Direct 12 volt power from battery - keeps memory and channel presets
Red - Wire from ignition to turn on
Black - Ground wire - best to attach to unpainted body metal
Orange - Dimmer - Not used
Blue - Not used unless you have power/electric antenna
Blue with white stripe - Not used unless running an amplifier, then it attaches to rem on amp
Gray/Black Right Front Negative
Purple - Right Rear Positive
Purple/Black - Right Rear Negative
White/Black - Left Front Negative
Green - Left Rear Positive
Green/Black - Left Rear Negative
Jan 30, 2010 | Aiwa CDC-X217R CD Player
CD Player not working
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Jul 02, 2009 | Aiwa CDC-X217R CD Player
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Wire harnest order
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
Nov 04, 2007 | Aiwa CDC-MP32 CD Player
Aiwa CDC-X217R CD Player Logo
549 people viewed this question
Top Aiwa Car Audio & Video Experts
Mike Duncan
Mike Duncan
fordexpert
Joaquim Martins
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
