Question about Toto - Toilet - One-piece - Neorest 500 - MS950CG.01
Toto neorest 500 take two flushes to work properly
Won't Flush properly take two flushes for it to flush all the way.
  • 979 Answers
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Posted on Jan 30, 2013
4 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Posted on Jan 28, 2009
  • 119 Answers
SOURCE: toto toilet does not flush properly - insufficient
Try holding the handel down for a few seconds each time you flush.
Posted on Mar 28, 2010
  • 12113 Answers
SOURCE: HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
Posted on May 31, 2010
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
My neorest 500 smells we have had it for 4 years. I am wondering what can be done. we love the toilet.
Smells usually come from the tank and not the bowl.
Buy tank deodorizer from local store located near toilet brushes.
http://secure.willert.com/images/bf_wire.jpg
Deodorizer hangs inside tank. make sure it reaches the water.
You can also drain and clean the tank using CLR calcium lime and rust remover.
The CLR and gunk are fine for flushing away as long as the gunk doesn't clog the flush holes that let water flow into bowl.
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Sewer line can also cause of odor.
If the toilet bowl is not full of water, or if nearby drain is not filled with water, or if toilet is not sealed tight against floor, or if toilet appears to have dampness visible around base, or if a vent pipe terminates behind a wall instead of on the roof: these things can cause sewer air to enter room.
Jul 28, 2011 | Toto - Toilet - One-piece - Neorest 500 -...
After automatic flush, water continuously runs into bowl. The water is coming from the upper bowl above the wand area.
i would think the syphon is not closing after the flush, so as the cistern fills it just runs straight into the pan. you'll need to replace the syphon...
Jul 07, 2011 | TOTO MS990CGR Neorest 600 One Piece...
After the flush and it fills up the water overflow keeps running
check the over flow valve shutoff and make sure it is at the right height
Sep 28, 2010 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
May 13, 2010 | Home
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Toto - Toilet - One-piece - Neorest 500 - MS950CG.01 Logo
273 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
