Question about Palm Tungsten E2 Handheld
Tungsten E2 wont power on
I have a Tungsten E2 and the battery ran dead and when i plugged it in, it charged for a while and came on...I left and and came back a couple hours later and the palm will not even power on now. I even had a different cord and that didnt work either? I tried using the reset button and still nothing....any ideas?
  • maxcommish Jan 27, 2009
    I have the same problem
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Posted on Jan 24, 2009
Tungsten 2E battery will not fully charge.
Your E2 is showing a battery that is just about dead. Luckily you can replace it
Aug 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Cannot charge new battery
Battery is not a known issue for this model, However 3rd party batteries causes some self discharge issue. Make sure the battery is not defective. The little charge circuit on the battery might have different threshold voltage also. Normally battery should show around 4Volts when fully charged. After save your data try full reset and complete discharge of the battery and try again
Good Luck
Jul 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2 won't power up
Please follow the steps to isolate the problem:
1. Make sure that the charger is working.
2. Try using different charger just to make sure.
3. Try using different battery.
If the phone works using different battery, you need to replace your old battery, but if not, this phone needs repair.
Apr 17, 2009 | Palm Tungsten E2 Handheld
Battery not holding charge
Don't got to the Palm store. Go to EBAY. 4 years is a fair longevity for your battery.
Jan 06, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Is this a battery problem?
If it's not the E2 going to sleep mode ;-), have it checked by a Palm service center .It might just need a new battery. Worst case scenario the charging system is faulty. Have it checked.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Tungsten E2 Handheld
Tungsten E
Hi : This means your battery must be as dead can be. Therefore it seems to be getting straight power only when you plug in the charger. Or your on/off button is dead. Are you able to turn it off/on when you have charge plugged. If so then I suggest getting a new battery for the E2 Palm and you should be back up and running. If this is not the case then it is your on/off button in which it could be just the contact or the switch itself. I can suggest someone in US if you like, else I can handle it but I am in AUS.
Oct 02, 2007 | Palm Tungsten E Handheld
Tungsten E
i have a tungsten e2 and it automatically turns itself on with out any buttons what so ever so the battery wont stay charged long enough for me to do any thing illput it up and come back an hour later to find the batter is already dead ill charge it unplug it and bring it to work with me to only find that when i get to work its on and the battery is draining what do i do
Dec 30, 2006 | Palm Tungsten E Handheld
Palm Tungsten E2 Handheld Logo
113 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
