Question about Panasonic KX T7130 Corded Phone
How do you cancel
Cant take off FWD/DND off and the phone will not ring.
Can you help
  • Panasonic Master
  • 2,460 Answers
Not knowing what the phone is connected to, the basic Panasonic command for cancelling FWD/DND is 7100/*7100.
As to the ringing, if your phone doesn't start ringing, please post the model number of the cabinet.
Carl
Posted on Jan 23, 2009
FWD/DND will not cancel on KX-TDA200
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help.
Mail me: omonat@yahoo.com
Make the subject be PANASONIC PBX
Aug 21, 2012 | Panasonic (KX-TDA200)
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
When i press the program button and FWD/DND buttons nothing happens
You have to set the button up first. You can press the FWD button (or press INTERCOM and dial *710) then x (500 or 165 for your voice mail) #, where x is 2 for all calls, 3 for busy, 4 for no answer and 5 for busy/no answer. That will set the FWD for calls. To set DND, dial *7101. Once you set those codes, your FWD/DND will toggle between the 3 steps of OFF/DND/FORWARD.
*7100 cancels the button. These are the codes for All calls. There are 711 and 712 codes for internal and outside calls if you need to split them. Also, the No Answer and busy timer can be adjusted by the *713yy command where yy is the number of seconds. A good number is *71324 which gives you about 4 rings.
This is explained in you phone system Operating Manual (OM) under Call Forward and Do Not Disturb.
Carl
Aug 24, 2011 | Panasonic KX-T7630 Corded Phone
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
Mar 10, 2011 | Panasonic KX-T7633 Corded Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Panasonic KX T7130 Corded Phone Logo
268 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
