Question about Executive Machines 10 Sheet Cross Cut Shredder SES D1026M Office Produ
SES D1026M shredder wont power on
I plug in the power cord and power doe not go on
How do you replace a power cord on a Staple shredder SPL-TXC12M7A
get an electrician in to do the job
probably a fault in the plug
Jun 21, 2015 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Repair
look up office equipment repair in your area
Jul 02, 2017 | Fellowes Confetti Shredder
What kind of extension cord fits it?
The machine probably uses a plug like the ones used on computers. It is a smaller plug, like a rectangle with two of the corners tapered. A regular extension cord will not work. Take it back, and look for a power cord for a computer. Take a picture of the plug on the machine you are trying to use before you go to the store. The clerk should be able to help you find the right cord.
Nov 15, 2012 | Staples ID Armor SH2836ID2836 Shredder
Can we use an extension cord with the Oztec 1275 shredder?
Yes you can. Just make sure that the plugs are not in a position where they can be kicked or trodden upon and that the cord itself will not trip people. Also make sure that the wire gauge of the extension is at least a little thicker than the shredder original cord. (Use a plugged extension cord, do not attempt a wire joint).
May 26, 2011 | Oztec 1275 Shredder
When i plug thr machine in the power light does not light up. Is their a reset button.
Hi your shredder may have a power problem or the power cord may be bad and you can also try plug the shredder into another wall outlet.
Aug 03, 2010 | Office Depot Ativa CX10W Shredder
New MacKissic chipper, wont start
it sounds like it is jammed up, take off the plug wire and look inside discharge chute for any debris.
Apr 04, 2009 | Heavy Machinery
Tech Solutions model #TS 5000 Cross-Cut Paper Shredder
my power cord seems to have overheated and the prongs won't stay out when plugged in. How do I purchase a new cord and how much does it cost?
Apr 20, 2008 | Tech Solution Office Equipment & Supplies
Executive Machines 10 Sheet Cross Cut Shredder SES D1026M Office Produ Logo
19 people viewed this question
Top Executive Machines Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Executive Machines Office Equipment and Supply Expert? Answer questions, earn points and help others
