Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Mi cable de corriente donde esta un foco esta parpadeando y no funciona porque lo conecto y no meda ninguna informacion ?
En el cargador hay un luz de color verde y esta esta parpadeando constantemente y es un hibrido de modelo hd500uhe5-72 de 500 gb
  • Acomdata Master
  • 27,725 Answers
Google translated
my power cord where it is flashing and a focus does not work because it does not connect and meda any information
in the magazine there is a green light is flashing constantly and this is a hybrid and hd500uhe5-72 Model 500 gb
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if this fails to fix the problem there might not be enough usb power for it to be recognised you might have to install a usb 3 card they are cheap and easy to install you can buy these on Ebay very cheap
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d $10.65 free postage You might get these on Ebay im not sure which country you are in this might guide you to one you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email Adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Hope this helps.
Posted on Jan 14, 2013
Donde se ubica el claxon
El claxon esta debajo de la base de la bateria ,pero por debajo de la lata del guardafango izquierdo, o sea casi atras de la pantalla de la luz , de todas forma si no le suena lo mas provable es que el problema este en el timon ,porque lleva una cinta enrollada como una cuerda de reloj que se parten,en el explorer 1999 es de 7 cables por el acelerador de mano o de velocidad crusero ,si no te funciona esto tampoco sacar el timon con toda confiansa que es eso . escribe para saber si lo solucionaste con mi ayuda . Ingeniero Marrero
Nov 16, 2012 | 1996 Ford Explorer
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Mar 03, 2011 | LG Office Equipment & Supplies
Hola tengo un codigo de falla p0301 en mi 99 ford mustang cobra y no se q hacer . ya cambie el coil y sigue la luz de check engine la bujia no es .y para conprobar desconecte el cable q ba ala bobina i no...
puede conectar una spark plug al coil y con corriente a tierra y si hay chispa, chequear el injector de gas, esto se deagnostica de la siguiente forma desconectando la coneccion de el injector si el motor cambia de forma como tembroroso quiere decir q el injector esta trabajando bien, ya solo queda chequear conprecion del los pistones
Jan 23, 2011 | Ford Mustang Cars & Trucks
Donde esta la valvula de carga de freon gas y si puedo hacerlo yo mismo y que tipo de gas necesita
PARA ESE CARRO TIENE QUE LLEVAR LO A UN TALLER PORQUE HAY QUE CAMBIAR EL FREON DE R-12 A R-134.TIENEN QUE HACER UNAS CUANTAS COSAS AL SYSTEMA DE AIRE PARA CAMBIAR LO.NO TRATES DE HACER LO USTED PORQUE NO TE TRABAJA BIEN Y LO QUE VAS HACER ES GASTAR MAS DINERO SIN TENER QUE HACERLO. ESPERO QUE ESTA INFORMACION TE AYUDE CON SU PROBLEMA. MANUEL
Mar 23, 2010 | 1985 Toyota Cressida
Compre un crosley cr2406a en miami y el librito de informacion para manejarlo no lo entiendo porque esta en ingles, aparte quiero saber sies compatible para argentina
compre un crosley cr2406a en miami y el librito de informacion para manejarlo no lo entiendo porque esta en ingles, aparte quiero saber sies compatible para ecuador
Jan 21, 2010 | Crosley CR248 Turntable
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Mstr2kx
Yenny salu2 desde Mexico...
querida amiga lo unico que tienes que hacer es presionar el boton de play por unos segundos asegurandote que el boton de Lock que se encuantra en la parte de atras no este en rojo, eso seria todo, si esto no funciona hay un pequeño orificio en el PD-6070 MP3 player que dice Reset presiona hay y repite la primera instruccion. Yo se que funciona lo hice con el mio. Espero que te ayude esta informacion...
Mar 12, 2008 | MyMusix PD-6070 MP3 Player
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
59 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
