Question about Westinghouse Refrigerators
Freezer will not get below 32 degrees but frig portion is ok. It seems it went into defrost mode and never went back to freezer mode.
    Genius:
  • 1,669 Answers
You probably need a recharge or the thermostat is not working properly.
Posted on Jan 13, 2013
  • 35 Answers
SOURCE: Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Posted on Jun 18, 2009
  • 3 Answers
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
Posted on May 10, 2009
herodog909
  • 98 Answers
SOURCE: Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
  • 208 Answers
SOURCE: my frig will not cool, my coils in my freezer are
unthaw your refridgerator and restart when un thawed
Posted on Jun 22, 2009
miket756
  • 2702 Answers
SOURCE: refrigerator warm freezer ok
most likley to be the thermostat for the refrigerator packed up, worst case a broken pipe or compresor
Posted on Oct 25, 2009
Freezer will not freeze ice cream and is not cold enough, fans are running,frig seems cool enough
Make sure that the evaporator is not covered with ice or the back of the freezer compartment is not a sheet of ice. If so, there is an issue with the self defrosting components of unit. Self defrost timer, defrost heating element, defrost thermostat.
Ice serves as an insulator and will prevent the freezer from going down to where it is supposed to be. And if you have an ice maker it will not function unless temps are below 10 degrees.
If the defrost mechanism is fine and you have no ice back there then it is possible that you are low on refrigerant.
Feb 03, 2016 | Refrigerators
My ge GSS22WGMCBB is not getting cold eonough - frig reads 60 degrees, freezer reads 38 degrees. What can be wrong? It's 10 years old...should I get it fixed or replace it?
either the compressor isn't running due to a faulty PTC overload relay on the compressor body or a bad compressor itself,you can test the compressor with an ohmmeter between the 3 terminals on the side of the compressor PTC is mounted,if its ok then it can be a defrost problem where its not melting the evaporator ice and blocking the cold air flow remove the inner rear wall of the freezer and test the defrost heater located below the evaporator coil as G.E. defrost heaters are notorious for failing,if its ok,then the defrost terminator on top of this coil can be bad(open)to test this component it needs to be below 15 degrees temperature to show good(closed) if ok then the mainboard located in the rear back of the unit can be defective because it controls all the units functions
Aug 25, 2012 | GE Refrigerators
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Maytag Refirgerator Model MTB2156FE freezer not cooling below 32 degrees
HI PAUL.FREEZER NOT COOLING could be for many reasons.go through the basics first .1-check if your freezer is iced up 2 if yes defrost it all completely first .then turn on 3-if ok then your problem could be 4-defrost timer 5-defrost heater 6-t/stat.if not iced up then check /clean thoroughly the condenser unit 7-check con/fan 8-check condenser should be warm/hot.if cold and motor hot then it could be lack of refrigerant (internal leak?) hope this helps.ALI
Jun 30, 2012 | Refrigerators
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Our Amana frig temperature is approximately 60 degrees with the lower freezer under 32 degrees. The unit is running constant. Any repair solutions would be appreciated.
Check and see if the fan is running in the freezer. If not may be bad or frozen. If is running check and see if there is any frost in the freezer if the fan is in the back then check the back wall of the freezer. If yes the it is not defrosting . Thaw it out for 24 hours and it will work for a week or so but it will need either a defrost timer, heater or thermostat.
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Jul 18, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
305 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
