Question about Gateway 103216 Motherboard Emachines Ms-6741 W/ 1394 / No Vga 100891 Sb 812bm Ms
Front panel wiring for ms-6741
I disconnected the the front panel wires ( PWR LED, HDD LED, PWR S/W ) Trying to reconnect them on motherboard. MS-6741 VER:1 Thank you.
2 Suggested Answers
lolita
  • 385 Answers
SOURCE: Motherboard Manual for MS-6389 Ver.1 S462 Motherboard
Hi, This is the closest manual I could find for this motherboard. The link below will lead you to download a manual for the MS-6380LE (the other models close to this were MS-6378 and MS-6390) However, it shouldn't be too different. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=287 Please let me know if you still have problem with connection. Thanks, Lolita
Posted on Jun 07, 2007
Msi ms 7297 ver.2.1 front panel help
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels;
PWR power
RST reset
HLED hard dive LED
PLED power LED
You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
Jan 06, 2013 | Intel Motherboard
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Reconnecting the pwr switch and HDD Led wires,etc
Hello here are the manual in pdf:
http://pclap.hu/driver_files/nf7_series.pdf
You will need adobe reader, to read content.
The front panel connector, look likes this:
Here are the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Sep 24, 2012 | Abit nForce2 NF7-S2 Motherboard
ASUS MOTHERBOARD A7V8X-X FRONT PANEL WIRING DIAGRAM
Most of the wires on the front panel are just for LED Lights other than the Power Button. Look on the motherboard for the abbreviated spellings of PWR for the Power Button, RST for Reset, HDD for Hard Drive, etc. Only the PWR will keep your system from booting up. If you place the others on the wrong set of pins the Led light will not illuminate.
Jun 02, 2012 | ASUS Computers & Internet
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
Nov 30, 2008 | E-Machines (308714) Motherboard
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
Gateway 103216 Motherboard Emachines Ms-6741 W/ 1394 / No Vga 100891 Sb 812bm Ms Logo
24 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
