Question about GE Dryers
Ge FRONT LOAD DRYER Pbvh520ejoww will no heat up
Stops heating intermettently
  • 19 Answers
SOURCE: how to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Posted on Nov 09, 2007
futureloginn
  • 734 Answers
SOURCE: ge dryer not heating
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
dragonsthatk
  • 547 Answers
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
How much do GE Dryer Replacement TIMERS cost?
The prices vary. Refer your inquiry directly to GE or an appliance parts supplier.
Jul 15, 2014 | GE GTDP180EDWW 27" Front-Load Electric...
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
GE energy star front load gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 18, 2011 | GE Dryers
Ge front load dryer not heating three years old model # dbvh520ej2ww
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Dryers
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
Dryer stopped heating
heatman101
Nov 08, 2010 | GE WSM2420T Top Load Stacked Washer /...
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
Dryers Logo
100 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
