Need wiring diagram for bosch wvt 1260 washer dryer
  • 1462 Answers
SOURCE: bosch wvt 1260
dry heater is located under an aluminium housing on top of the machine. take it to bits and easy to fit. however, why do you need a heater? if no heat on dry, cause is probably overheat stat operated
Posted on Mar 31, 2007
blueextc3221
  • 15935 Answers
SOURCE: i have a bosch wvt
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 6277 Answers
SOURCE: Want to buy a new
Sorry. As we are scattered all over the world it would be difficult for anyone on the forum to tell people where their 'local' suppliers are, even if we knew where they were ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Posted on Mar 14, 2011
  • 6277 Answers
SOURCE: BOSCH WVT 1260 is malfunctionig,
From your description I would suspect there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 08, 2011
  • 6277 Answers
SOURCE: My Bosch WVT 1260 is
Manual first then 'F04'!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
'F04' means 'pump blocked'
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Posted on Jul 22, 2011
Need cleaning product for inside washer/dryer
you need Afresh this is the name of the product that is reccomended by Whirlpool
Mar 29, 2014 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch washing machine WVT 126S, error F01 on the start. Please help
F01 means the machine thinks that you have pressed start and the door is still open, so, either the door is not completely shut or you will need a new door interlock (part number 182154) you can get the part by calling 0844 892 8979 (UK) or http://www.bosch-home.co.uk/customer-service/spare-parts-accessories.html. Or the connection to the door lock is not loose or detached.Hope this helps
Aug 28, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
Hi, I've got a Bosch WVT 12840GB washer dryer and
the faster the spin the more you will enjoy the ironing?????? if you do a 1000 spin at the end of a wash see how it goes
May 25, 2011 | Bosch Washing Machines
Want to buy a new door seal for my bosch wvt 1260 washine machine. can you advise where? thanks
Bosch Exxcel WVT 2850 Front Load Washer / Dryer
how to change a door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine and where to get a new door seal!
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
Tumble Dryer is not working - it runs but there is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Bosch Exxcel WVT 2850 Front Load Washer /...
Do not have operating instrutions for bosch exxcel washer dryer
see if you can go on line and download the manual fron the maker of your machine if you cannot find go to Google and type in what you need
Jan 07, 2010 | Bosch Exxcel WVT 2850 Front Load Washer /...
Drying cycle working but not drying clothes
First clean filter for lint - next be sure the temp sensor at blower if free of lint - next, in the heater contrl unit, two solinods contrl the heating process - I hope it's the first two ideas - Try it - Good luck
Oct 15, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Exxcel
Check the drain pump. It may be jammed. Remove filter and try to turn impellar by hand . If not turning freely, replace pump or remove obstruction.
Oct 31, 2007 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch wvt 1260
Mar 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
