Question about Drills
How do you change the battery for a skil drill 2125
How do I get to the battery to change it or should I buy a new one
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
  • 3 Answers
SOURCE: How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 24, 2009
  • 583 Answers
SOURCE: my skil drill with 14.4 battery will not work on
no it is not recommended that you leave it plugged in for much more than it takes to charge the battery ,which incidently i think you will find to be u/s it may not be,just not being charged.your tool store will be able to test them. if it happens they are stuffed ,in that range it will cost more to re place those things than to buy anew one good luck
Posted on Aug 14, 2009
  • 112 Answers
SOURCE: The green power indicator on the charger for my
factory defect in the charger i think if out of warranty check fuse inside the charger.
Posted on Nov 29, 2009
I need the charger for a Skil cordless drill model #2125.
I have the 2125 Type 1 Charger and the Charger Base. My drill no longer works. Email me at Thrifty0809@yahoo.com if you want my charger kit.
Oct 12, 2011 | Drills
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
My battery will not charge
Supposedly there is , But I don't think so, There is a video on you tube that shows somebody messing with them, I think it is a bunch of ****. Is it the battery or the charger? Do you have other batteries that charge up? The life of the battery is about 1 year. I have boxes full of dead batteries, and guns and chargers. It is cheaper to buy a new gun with batteries and charger than it is to buy 2 new batteries. Check it out.
Jul 11, 2010 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
14.4V Charger doesn't work
This must typically be the Batteries themselves in the Drill. Usually, rechargeable batteries give out after a couple of charges, if it has handled few charges, then it must be a fault within the Charger. But I'm sure a battery replacement would be fine :)
Apr 02, 2010 | Skil 14.4 volt Drill with Built - in Stud...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Skil cordless drill model 2362 - won't charge
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Dec 19, 2008 | Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
