Question about Vehicle Parts & Accessories
Hi i have a ls400 security alarm. Problem is the
Hi i have a ls400 security alarm. Problem is the external siren doesnt have a strobe light fitted. I was wondering if one can be fitter to the exsisting siren?
c renner
  • 43 Answers
SOURCE: wirng up a bw10000 car alarm to a dj systems siren
If you're connecting at the alarm module - you want the red wire from the siren to go to the brown wire on the alarm(the one that's in a plug with 12 or so other wires), not the red (red wire is the constant power input to the alarm).
Posted on Feb 24, 2008
SaintGene
  • 53 Answers
SOURCE: hi lo alarm siren when playing online games
Hi stretcharm_2,
It seems that the hi-lo siren from the mobo indicates that the cpu is over hated.
1st of all, you need to go into the BIOS/CMOS setup to check if the temperature was boosting higher that the prefix alarm. If it's low, but gone up very fast after a few minutes, you need to update to the latest BIOS firmware, as it's part of the Fatal1ty problem.
you can download the bios here, be sure to read all the instruction before you proceed to update the BIOS firmware.
http://www.abit.com.tw/page/en/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=motherboard&pTITLE_ON_SCREEN=Fatal1ty+FP-IN9+SLI&pSOCKET_TYPE=LGA775
PLEASE BE EXTRA CAREFUL WHEN UPGRADING THE BIOS AS IT MIGHT KILLED YOUR MOBO.
you can always come back here and post a comment if you r no sure.
2nd of all, you need to check is the heatsink was fixed properly.
It's not your fault that's the fan wasn't fixed properly because the stock LGA-775 socket T heatsink's design wasn't a perfect one, and it has 4 very fragile fix-in clips. You need to check if all four clips were fixed firmly in the braket for maximum heat dicipation. It might be broken and you need to replace with another one.
You might need to replace the thermal paste to a better 1.
Please check your manual on how to diassemble the heatsink.
Good Luck,
Don't forget to rate my solution, thanks!!
Posted on Jan 17, 2009
RaidX
  • 632 Answers
SOURCE: i have a 95 bmw e36 coupe fitted with a gemini
this could be due to a defective alarm sensor unit.
Posted on Jun 22, 2010
  • 74 Answers
SOURCE: Ademco 4160-12 was installed in my house in
Any 12V DC siren should work. If you need a manual for the control contact the Professor.
AlarmProfessor.net
Posted on Aug 23, 2010
marksheerin
SOURCE: fitted a yale wireless alarm soon has i open my
You need to go into the devices menu then the edit devices menu and then programme your door contact as an entry device. All devices when first added to the system default as burglar and activate immediately. You have to tell the system which devices you would lke a delay on.
I install Yale Alarms throughout Yorkshire
Posted on Jun 02, 2012
Is the a 12v power adaptor for the Yale easy fit siren EF-BX unit that can be fitted to the siren instead of the batteries ???
Because your system is designed to operate off of batteries only, coming up with an external power supply to work around the original design becomes an issue. In order to do what you want to do you would have to have a rechargeable battery maintained by an appropriate charger that would run the system from the charger/supply, charge the backup battery and switchover to the battery in the event of a power failure. These do exist and one manufacturer is Altronix but there are several, you just have to visit a DIY alarm website and get recommendations bearing in mind the battery voltage your system is designed for and the amp hour rating necessary to keep the system running the duration of the power outage and beyond. Keep in mind the reason for your alarm system is security and compromising that with homemade non-UL retrofits might not be the way to go, your choice.
Dec 06, 2014 | Cars & Trucks
I want to know what is needed
There is a control unit that is apart from the keypad. There should be terminals that allow you to connect lights and alarm devices. It would be a big help if we knew the model of the system that you have.
Jun 14, 2014 | Siren Wireless Security System House...
What is needed to put a self contained siren in a wireless honeywell lynx plus keypad
5100 or 5200 is here http://www.security.honeywell.com/hsc/products/intruder-detection-systems/control-panel/wireless-burglary/
My car alarm siren will not go off
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit... Post results or additional questions
Dec 30, 2013 | AviStart 5303 2-Way Security / Remote...
I have a Gemel Serpi Star alarm gr40 fitted to a 1991 bmw E36, I need to find a wiring diagram, can anyone help. Thank you
Im trying to fit an E90 siren to my E36. Were you every able to get the siren working? please email me at weber.ryan1@gmail.com either way
Apr 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
No sound coming out of siren from alarm. hooked hot and ground diretly to siren no sound. bad siren?
put a 12 vt test light on your 12vt output to see if the alarm is outputing,some alarms have to be programmed for positive output as some are negative output ie;set up to hook up to horns.Also double check your earth.
Apr 12, 2009 | Vehicle Parts & Accessories
I have no sound coming from my AU-93 car alarm
probably the siren is damaged hook up another one or try with a tester light on the wires from the siren when the alarm is on and the lights start to flash the light on the tester light will stay on.if this happen then your siren is damaged.or email me for more help, reynosaelectronics@live.com.mx
Mar 16, 2009 | Vehicle Parts & Accessories
Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Feb 22, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
