Question about Hotpoint WF645 Front Load Washer
Hotpoint acquiarius WF645
My machine has the word 'test' on the display and I can't get it out of this mode, or get the door to unlock. There is already a similar problem posted on this site for another model, but on the wf645 the start and the cancel are both on the same button. I have tried cancelling, turning off the power, every combination of buttons that I i can think of .
  • Anonymous Jan 28, 2009
    Machine will not start and the display will show TEST I tried pressing start and on/off button together but it will still display TEST
To exit test mode, press start, display goes wild) press start again (display settles down) Then press on/off button and start buttons to gether and hold for a few seconds, machine will now read D;end, or similar, will now work okay
Posted on Jul 11, 2007
SOURCE:
My Hotpoint WF645 washes ok but is very noisy, especially during the final spin. Any suggestions why this might be?
sounds like it could be a bearing going out, or simply might be something stuck around the drum
Aug 13, 2010 | Hotpoint WF645 Front Load Washer
Washing machine it test mode
To exit the DEMO/TEST mode, press and hold down the "On/
OFF" and "Start/Cancel" buttons until "d off" is displayed
Mar 14, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius wf645 when i put it on a wash cycle it will fill for 1 minute then drain a message comes up F-o7 please help
hold in the start and cancel buttons for 10 seconds, a "test on" message appears, hold in the start and cancel button again for 10 seconds and "test off" message appears, set your wash to whatever mode and it should work...it did for me!
Apr 26, 2008 | Hotpoint Washing Machines
Test on washer display
Try pressing the "on" and "start" button together for over 5 seconds..............
Apr 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Hotpoint WF645 Front Load Washer Logo
310 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
