Question about Plumbing
Our daughter put 3 bath crayons down our tub drain and completely clogged it. We've tried all brands and variations of daino as well as a small hand snake. I'm thinking we'll need to disso
How do you dissolve bath crayons?
    Problem Solver:
  • 19 Answers
The right answer is to remove the drain trap and clean it out.....if this trap is not accessible then you have a major carpentry issue to gain access. You can also try several gallons of boiling hot water to soften the crayons up.
Posted on Jul 19, 2013
  • 148 Answers
SOURCE: drain clogged
Trish
What i believe you have done is puled the linkage and the drain remains clogged.
Here is the fix:
remove the two screws from the overfow chrome cover that has the drain handle
Slowly pull the wire linkage out and hopefully the plumb bob plug comes out if just the linkage wire comes out out wil have to use a coat hanger and flashlight to fish it out you now shoud get the drain to drain
once you remove the plug I am still not sure you can retrieve the sword. There is a tool that is T handled that you insert down into the drain hold that you turn counter clockwise and the chrome drain piece comes out
I highly recommend that you have someone handy ( has done plumbing) to do thispart because
it has to proberly reinstalled with plumbers putty to seal properly
Before you do the t handeld part try using a hemostat to grip the sword
Posted on Jan 01, 2009
frcs68
  • 1605 Answers
SOURCE: clogged drain
there is plastic plug that is used to stop the drain, when you pull the handle.
seems like the chain is broken off the the drain plug. the drain plug is one way plug.
the only suggestion I have is to open the backwall or the ceiling to get to the drain pipe. then you have to open the drain in order to fix this problem.
there is no easy fix, since you can't get to the plug that is in the drain, and the more you pull, the tighter it gets.
I don't suggest try to push the plug down, it may clogged the drain somewhere else.
Posted on Jan 06, 2009
  • 349 Answers
SOURCE: I have aKohler bath drain that seals/drains simply...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
Posted on May 25, 2010
  • 126 Answers
SOURCE: how do you get the drain out of the tub so you can
take out the overflow (trip lever)and send the snake down there
Posted on Jan 18, 2011
  • 3640 Answers
SOURCE: I can not close my
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Posted on Aug 22, 2011
Pumbing problem
You have a vent on the roof that may be clogged with debris or some solid object. You toilet works when this air vent is completely. Otherwise it will function like putting your finger over the end of a straw with water in it. The water won't drain out until you take your finger off it. This is essentially what is happening. You have a partial to a complete blockage.
Feb 09, 2013 | Home
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off...
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
May 19, 2011 | Kohler Archer Clearflo 1-1/2in Bath Drain...
Both toilets and bath tubs are clogged.PLEASE help . its a crane but i dnt knw the model.
You have a main drain clog. The sinks are clogged too (run water and you will see it come up the tub). Is this a one floor house? Basement? You probably should call a plumber unless you are willing to take on the task of snaking it yourself. Sounds like you may have a house on a slab? (no basement)?
Dec 27, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
Tub drain will not stay in up position
Hi it may well do clogged up in drain hole or it may have come loose inside try tighenting up
Dec 20, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Sewer gas smell from tub.
Something was flushed that should not have been flushed
You will have to have your drain snaked out.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Drain clogged
Trish
Here is the fix:
Jan 01, 2009 | Eljer Arlington Non-Jetted Acrylic Bath...
Clogged drain
Haier drain tube keeps popping out during/following drainage.
are you able to glue or put a hose clamp on the hose.hope this helps
Mar 03, 2008 | Haier XQB40-F Top Load Washer
Plumbing Logo
312 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
