Question about Dometic HZB-15S Portable Ice Maker Top Load 120V Camper Trailer RV
Waterwell ice maker mod: HZB 15 error code " add water" even though tank is filled
  • Juan Buter Jan 16, 2013
    This ice maker gets filled by hand, I'm sure it must have sensor to tell the icemaker that it can start making ice as soon as there's enough water in it, maybe this sensor is faulty leading to the blinker for "add water" to stay on and start making ice?
Mine was having the same issue. The trouble-shooting section of the owner's manual mentions cleaning it but doesn't state where it is at. When I contacted Dometic they stated it is in the center of that circular hole in the bottom of the water resovoir, however, they couldn't tell me how to remove it.
Through trial and error, I found that it's just a little basket that fits snugly inside that hole. You DO NOT have to remove the round part that you can see. I used a pair of pliars in an attempt to remove the entire thing and the little basket (looks like a clear plastic thimble) came right out of the center. (If you have good hand strength you can likely just pull it out without using pliars.) I cleaned that off, placed it back into the ice maker and we are back in business. It is making ice as it should now.
Posted on Jan 16, 2013
2 Suggested Answers
luck_is
  • 5 Answers
SOURCE: Dometic ice maker is not filling with water. How should we troubleshoot problem
is water line connected, and turned on??? if so, check for a plugged filter, kinked supply line.
Posted on Jun 06, 2012
Where can I get replacement parts for ice maker
The link below will give you lead to a supplier. I don;t know anyone at this dealer but hopefully you will get the parts you need.
Dometic HZB 15S Portable Ice Maker 120 Volt RV Parts
Feb 19, 2015 | Dometic HZB-15S Portable Ice Maker Top...
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
Ice maker is cycling water through every 15- 30 mins but not freezing.
see if unit getting hot on back if not electric or LP bad cooling unit or board
May 09, 2014 | Dometic Portable Ice Maker HZB-15S
Ice-maker has stopped working. Mod. ED25LFXHT02 Ser. SL0435597
Has it stopped because it ain't gettin water? Or has it quit because of internal failure of some sort. A nice thing to know is just how ice makers work. The ice maker does all the thinking. It calls for water and it knows when to take a dump. Nothing else in the ice box makes the ice maker do what it do. If you have no ice in the mold add some H2O to it and see if it indeed kicks out some ice. If it does then you needs ta look at replacing the water valve and even the water filter (I would). If you have ice in the mold but none in the bucket then that could be the ice mild thermostat. An easy fix. I have repair photos,video,and manual: HERE
Mar 27, 2010 | Refrigerators
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Getting ''Fill Water'' message even though Tank is full
Gently remove tank the slide it back in place make sure the back of tank makes good contact with the machine when it is being lowered so that the reed switch can read the magnet in the tank.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Dometic HZB-15S Portable Ice Maker Top Load 120V Camper Trailer RV Logo
796 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
