Question about Samsung HL-P6163W 61" TV
High pitch noise from the flyback
High pitch noise coming from the flyback, it comes and go, there's nothing wrong with the tv except for that noise. i have posted my problem yesterday and someone have answered it he said that i should replace my flyback, thank you for the advice dude. last night i tried to tap the rear of the tv and the noise dissapear. if the noise will come again does it mean that the flyback really needs replacement?
    Problem Solver:
  • 9 Answers
Yes you must replace the plyback because we will damage other parts of your tv...the high pitch noise u hear is a high voltage current passing out in your plyback ....
Posted on Jan 23, 2009
    President:
  • 2,559 Answers
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Duralast 750 is completely dead and make high
high pitch noise is coming from the Flyback Transformer. Faulty power supplies issues.
Aug 31, 2014 | Televison & Video
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
High pitch sound coming from back of TV?
it could be either the coils on the yoke of the tube or the flyback. flyback would need to be replaced it that is the problem
Apr 19, 2009 | Curtis-Mathis CM19011 TV
TV is making a loud high-pitched noise that goes on for about 2 - 3 minutes. Its coming from the lower back part of the TV not through the speakers. Sometimes the noise pulsates and makes the picture jump...
The flyback is getting ready to fail. Its a very easy and inexpensive repair. You need flyback 259296 and CP150 you can get the parts at the following link with free step by step instructions.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA HD52W59 HDTV Projection Television
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
RCA F27442tx51 dead but making high pitch noise
Update on finding replacement tripler (Flyback Transformer) for RCA F27442tx51. This is a follow up on my report dated Jan 12 2008. Further investigation revealed the Horizontal drive transistor was also blown. It is a 2SD2578. Internet search turned up ACME ENTERPRISES in Orlando Florida. www.acme-slaes.net. Surprisingly they also sell Flyback Transformers as well as other TV repair parts. The cross reference for the needed Flyback is ACME-2236 FBK. The part number for the transistor is 2SD2578 SANYO TRANSISTOR. The price for the transistor is $2.69. The Flyback is $22.95. Shipping to CA is $6.75 and handling is $1.99. Two days after ordering, the parts were at my front door. The set works now except the picture still goes off after 5 minutes or so and then comes back on, sound still works during the dark period. The original symptoms before it blew out in the middle of the night and started chirping. I now have the set on the bench attempting to find the intermittent part. Stay tuned I'm on the hunt.
Eng Don
Nov 19, 2007 | Televison & Video
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Samsung HL-P6163W 61" TV Logo
493 people viewed this question
Jerry Greenberg
Jerry Greenberg
