Massstorage i want to install windows xp2 to my wrksation and when i boot from cd after min, the following msg been : check ur hardware or hardware controllers , i have work station hp xw600 with 1000gb harddisk
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
Step 1: Format the Drive
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Plug in your USB Flash Drive
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
Find the drive number of your USB Drive by typing the following into the Command Prompt window:
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
create partition primary
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Step 2: Make the Drive Bootable
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Insert your Windows Vista / 7 DVD into your drive.
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
Step 3: Copy the installation DVD to the USB drive
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
Step 4: Set your BIOS to boot from USB
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Posted on Jan 27, 2009
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
How to test a hard drive to check controller cannot load or format mine or from cd and do not have boot disk can you help
What is ur OS and board? Upon starting click on "del" to go to BiOS and go "BOOT" sequence, choose CD ROM as ur 1st boot sequence! Exit w/ save changes! Now ur ready to install a new Windows OS, insert a OS cd and re start ur desktop! upon starting "START CD ROM" click on "enter"! Let ur windows do everything and follow the instructions!
Taaa!
Nov 08, 2010 | Computers & Internet
I cannot connect the phone usb driver to pc and place pics from phone to labtop
1. use the pcsuite ur mobiles,
(or )
1. plug the usb to pc, windows in small msg box appear ( ur mobiles hardware install msg box ),
2.now clix the msg,
3. follow the instruction finally asking ur mobile software source place select ur saved source place,
4. finish ok,
then after u get the everything in pc.
Sep 05, 2010 | Samsung SGH-t239 Cell Phone
Inspiron 1525 Error Code 4600:021E msg: Processor
There are several Reasons.
  1. Your Processor heated up more than the expected limit. Often caused by a trouble with Heat-Sink(and or the Copper tunnel if have one inside), Short Circuit. You have to check the Processor and its Socket.
  2. CPU fan is not functioning: You have to check whether the fan works properly (with a good speed - rpm).
  3. Your Sensor has a fault. You have to check the Sensor.
Jun 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
How can i reformat my laptop?
  1. First format all the other partitions in your system except the Drive in which the OS is installed.
  2. Most probably the OS drive is C: Drive.
  3. Then get an operating system CD/DVD Windows XP/Windows Vista/Windows 7
  4. Then on start up insert the OS cd and select the option to install the OS.
  5. When you click next there will be an option to specify the Drive in which you will be installing the OS.
  6. Select the Drive in which the previous OS had been installed.
  7. Now in the next stage there will be option whether to install the OS with or without formatting Drive.
  8. Select the Format Drive Option and click Next.
  9. Congratulations you have formatted all the partitions in your System/Laptop/PC
Apr 05, 2010 | Computers & Internet
Hi i allready downloaded the audio driver for the presario c500 after installing thte error msg is displaying "can not find audio device" pls guide me stilll not saloved. ajitha
hi.......... if ur having windows xp2 os cd once change the os of your laptop. if the problem repeat's again take any intle cd. which is given by any desktop you will find audio drives in that cd instil it then you can here the audio
Oct 04, 2009 | HP Compaq Presario C500t Notebook
How to instal xp2 in dell laptop
try this!
if you have a xp2 bootable cd,..insert it on your cd-drive
step1: power on your laptop , then press dell until you view the bios set.up
step2: then go to boot sequence: your first boot is your ( cd-drive ) where your cd xp2 is in....
note: in boot sequence just follow the reference of your laptop settings...
step3: if you finish seting up the bios set.up,..just save and quit...then it will automatically restart...then wait for instructions view on your screen...
Mar 10, 2009 | Dell Vostro 1510 Laptop
How to format acer aspire 4710 with xp
actually there is no need to touch anything in hardware please do not touch ur hardware without any reason i know what eactly is the solution is now follow this :
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
Solution:
this specific model Aspire 4710 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset Mobile Intel® 945GM Express download SATA RAID DRIVERS and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
important tutorial links
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
pls let me know if i can help u more
Feb 21, 2009 | Acer Aspire 5610-4648 Notebook
Re installing windows xp
go to the bios using either f2 or delete key......change the 1st boot device to cd drive....exit the bios & u will get a msg "press any key to boot frm cd"....press any key on the keyboard & it will start loading the files....soon u will get a setup windows screen...simply follow the instructions & the installation wil continue
Jun 28, 2008 | Dell Inspiron 300M Notebook
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
