Question about Firefield 2.5-10x40 Riflescope with Red Laser FF13011
How to repair my fire field ff13011 - Firefield 2.5-10x40 Riflescope with Red Laser FF13011
Motor stopped running when out in field would turn over but not fire up
Did you know that a farmer is out standing in his field ... and if it rains, he's going to get wet?
What motor, on what brand and what model of what? I have tried and failed many times, at being a mind reader!
Apr 24, 2017 | Cars & Trucks
I AM LOCKED OUT OF MY KINDLE FIRE IT KEEPS ASKING ME FOR A PASSWORD AND I NEVER SET ONE.
If you can't remember the password for your Kindle, you can reset your password to regain access.
To reset your Kindle if you don't have the password:
Kindle Touch
1. Press and release the power button to turn on the device or exit sleep mode.
2. Enter "111222777" into the passcode field and select OK.
Kindle
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field and use the controller to select the enter key.
Kindle Keyboard
1. Slide and release the power switch to turn on the device or exit sleep mode.
2. Enter "resetmykindle" in the password field and press the enter key on the key pad.
3. Wait several minutes while your Kindle restarts.
Kindle FIRE
2. In the password field, attempt to enter a password 4 times.
3. When password is incorrectly entered 4 times, you will be prompted to reset Kindle Fire.
4. Select "Ok reset".
Feb 16, 2016 | Cell Phones
How do i change my passcode on a kindle e book reader
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
To reset a Kindle (5-way controller):
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Mar 04, 2015 | Amazon Kindle Dx, Free 3g, 9.7" E Ink...
I didn't realize that was putting a pass word n .How can I open my kindle/
Forgot my password
Mar 02, 2015 | Amazon Kindle Fire HD
How to unlock kindle fire
Forgot my password
Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
I have a lt1000 with a 17.5 horse briggs was running great died one afternoon and has no fire to the plug. keeps fouling the plug. what could be the problem.. How do u test the magnito and where does it...
you can use a neon bulb voltage tester to check for spark
a magneto gets its spark from the collapse of the magnetic field that occurs when the points close
the magneto is comprised of two coils.
a primary and a secondary.
when the points are open the primary and secondary are one continuous circuit and generates a considerable magnetic field when the magnet passes the magneto.
when the points close the primary coil is shorted to ground.
this causes a very rapid collapse of the magnetic field in the magneto.
this field collapse can generate a very high voltage surge (the power for the spark)
this surge can exceed 12,000 volts or more and yes it is a bit painful
Sep 08, 2013 | Garden
What is a military pillbox?
Pillboxes are concrete dug-in guard posts, normally equipped with loopholes through which to fire weapons. The originally jocular name arose from their perceived similarity to the cylindrical and hexagonal boxes in which medical pills were once sold.They are in effect a trench firing step hardened to protect against small-arms fire and grenades and raised to improve the field of fire
(wikipedia).
May 07, 2013 | Home
Mazda b2600 charge light on and not charging changed alternater and fuseable link but no go
Then you have a field problem without the field you wont charge B2600 uses a voltage regulator it at the side of the fire wall it a square metal box either you adjust or replace it
Aug 21, 2011 | Mazda B2600 Cars & Trucks
The depth of field preview function of my Nikon F80 (N80)
needs repairing at a qualified shop, when was it last cleaned or serviced ?
Jun 21, 2010 | Nikon F80 35mm SLR Camera
Firefield 2.5-10x40 Riflescope with Red Laser FF13011 Logo
Top Firefield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Firefield Optic Expert? Answer questions, earn points and help others
