Question about Tricity Bendix AW1000W Front Load Washer
How do you remove the programmer knob on a tricity bendix AW1053W washing machine
  • david knott Jan 15, 2013
    The programmer is also known as the timer. I need to remove the timer/programmer in order to gain access to remove the drum
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
barkencoa
  • 3463 Answers
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Tricity Bendix AW1053W Stuck on cycle 2 (Whites @ 90)
Possible that the drain pump is struck or clogged and does not finish the cycle.
Remove the drain and clean, click this link: drain pump.
Jul 05, 2012 | Washing Machines
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
My Tricity Bendix AW1400W washing machine will wash but not drain. I was told I have a faulty pump which I immediately changed but the problem still persists. Can you help?
If you have replaced the pump check that the pump is actually working the easy way to tell is to remove the filter and shine a torch up inside put machine on spin or drain and see if the impellor on the pump is rotating if not then the problem could be in the wiring or the main programmer is faulty.
Apr 14, 2010 | Tricity Bendix AW1000W Front Load Washer
How do i change door seal on tricity bendix AW1053W washer
Unfortunantly , that should be done by personel with experience .
Jul 10, 2009 | Washing Machines
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix AW1053W front loading
Either you have a clogged line going from the compartment to the tub or the valve is sticking for the softner.
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
57 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
