Question about Garmin Nuvi 50 LM
My screen on my garmin nuvi 50 lm is frozen how do i reset it
  • 18 Answers
SOURCE: garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
Posted on May 09, 2008
  • 11 Answers
SOURCE: Garmin nuvi frozen
Did you press the reset button located under the antenna?
Posted on Aug 10, 2008
  • 1111 Answers
SOURCE: my garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Posted on Sep 27, 2009
SQUIRESXX
  • 486 Answers
SOURCE: My brand new Garmin Nuvi 1300 is frozen on the
try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, failing that take back to seller if under 12months old
Posted on Dec 27, 2009
SOURCE: Garmin Nuvi PIN reset?
I think the true purpose of the pin is for another income stream to garmin they want $110 to unlock it. If not then why not just register a pin when you register for the warranty then just use your MY GARMIN to get it when you need it???
Posted on Mar 20, 2010
I am trying to factory reset my garmin Nuvi 50lm. It is powered off for certain, and used my finger, a pencil eraser to hold down the bottom right corner for several min, nothing happens.
If you've tried the normal reset (hold bottom right corner of the touch screen while powering on) and that has not worked, it is time to talk to Garmin.
Hopefully, your unit is still supported and they can repair it.
If your unit is out of warranty or no longer supported, the ultimate "hard-reset" is to open the unit and physically disconnect the battery lead from the circuit board. There are videos on You-Tube.
My Nuvi 1340 screen went bright white when turned on last week - no supported - now in the bin!
Nov 06, 2016 | Garmin Nuvi 50 LM
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
It is stuck on the Garmin screen
Most likely a boot-up issue. Please see this link for more info on this problem. Typically caused by a corrupted map or system file.
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Jul 03, 2015 | Garmin Nuvi 50 LM
Garmin troubleshooting
try a master reset after you back up your favorites or try plugging it into the computer and updating the Software. this could fix it.
Jul 27, 2014 | Garmin Nuvi 50Lm - Gps Receiver
Turn on, Garmin screen comes on, then a screen showing press dot comes up and won't go any farther
does it still happen when plugged into a computer ?
might be a problem with the battery
or it might be a lead connection problem if you are tech minded there are youtube video's that show you how to replace garmin batteries and to dismantle garmins
not sure if this garmin is the right one
http://www.youtube.com/watch?v=zVwMHpNIVjQ
hope this helps
Oct 03, 2012 | Garmin Nuvi 50 LM
Problems and Solutions for Garmin nuvi 50mlm
watch this
http://www.google.com.pk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&ved=0CCoQtwIwAg&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaJPfCgeA4qQ&ei=KCBsUMPOGcOGrAf1p4GQDQ&usg=AFQjCNHTuF3EI5sKMAVohYR2Q4_GgfrqBQ&sig2=nbo0U02VLl1g1kl1H9M2eg
Garmin nuvi 50 LM froze
Press the small reset button for 5 seconds then power the unit off and then back on again. This should clear the problem.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Garmin Nuvi 50 LM
How to install the LCD touch screen for garmin 50 LM
there are many youtube videos that show you how to replace touch screens on just about anything. www.youtube.com/ good luck !
Sep 01, 2012 | Garmin nuvi 1350 Car GPS Receiver
Nuvi 50 LM touchscreen claibration
Hold your finger in the center of the screen. power on. Keep finger on screen and after 45 sec see a black dot on a white screen displaying touch me.
Jul 26, 2012 | Garmin Nuvi 50 LM
Garmin Nuvi 50 LM Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
