Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I stupidly filled my kerosine/diesel heater with weed killer and ran it for a few seconds before it cut out and i realised what i had done, if i drain it and fill it with the correct fuel will it be o
Not the exact same heater but allong the lines of this... HELP!
  • Reddy Master
  • 3,315 Answers
You will have to clean it all out every where the fuel goes tank , lines igntion etc if you had not run it you could have just changed fuel , now its best you clean it all .
Posted on Jan 14, 2013
Testimonial: "would it be best just takin it back to where i bought it and getting them to do it? as tbh i dont know how i would go about cleaning the lines and ignition. thanks for your help! :) "
  • Paul Carew Jan 15, 2013
    Yes good plan
3 Suggested Answers
SOURCE: when filled with kerosene then plugged in, the
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Posted on Jan 20, 2010
tbugger
  • 232 Answers
SOURCE: my reddy heater 70,000 btu.
Assuming the "electronic safety shutdown system" is operating properly, the system is shutting the heater down becausr the control board/photocell don't like what is being seen inside the combustion chamber. That is what they are supposed to do if there is water, trash, an air leak, a vacuum leak, a broken ignitor, a worn nozzle, etc.
Your job, as the troubleshooter, is to find out why the flame is not correct. Read the tips below:
Troubleshooting tips
Posted on Nov 24, 2010
I'm looking for parts for Dyna-Glo Rmc8000. I need a gas line and a thermocouple any help
The therm can be bought at a applience repair shop. It does not have to be exact to work. Gass lines can be found at the same place and an auto store has pipe. Another option is getting a barbuce repair kit for the hoses if they are the same size
Jul 18, 2011 | Dyna-Glo RMC-8001SS Heater
I Have an old M30 REDDY HEATER, It won't start, Good Spark, Good Fan, Clean fuel, Pump has some pressure- I have no-idea on how much is needed, Not sure about the in-out of fuel lines to the Main Jet...
The line from the pump to the nozzel should go inthe front fitting and the one from the tank goes to the backfitting. If either of these have cracks in them or do not fit tightly over the fittings it will not build enough pressure and burn. You may also check the filters mainly the output filter as this will also effect pump pressure. I don't have as much experiance with that brand so I can't be sure exactly about the pressure. I think it should be 3.5 to 4 Psi. If this doesn't help please email me and I will find out for sure.
Feb 02, 2011 | Reddy Heater-30-55,000 BTU Variable
94 gmc sanoma. heater dampers do not work properly. can hear a vacuum leak at rear of heater control switch. new switch at dealer is not available,junk yards no luck. the vacuum hose configuration is what...
From the feed line under the hood,have an
assistant(engine off) blow cigarette smoke into the line,you should be able to see exactly where the leak is.Often is is a hose,not the switch itself.
Oct 05, 2010 | 1994 GMC Sonoma
KV 13R20 SONY TV WITH OUT A REMOTE AND I FOUND A UNIVERSAL REMOTE WITHOUT PROGRAM CODES WITH THE NO# 29-0003 HG-29#3 ON THE BATTERY COVER PLEASE SOME ONE SEND ME THE CODES FOR THE REMOTE SO THAT i MAY...
You can go on line and go to the web page for the brfand of the unevirsal remote and it should let you get the manual for the remote allong with the codes for all the diferent brands of tvs
Dec 18, 2009 | Televison & Video
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
No ds game inserted
it is a very common problem with the nintend DS console, its to do with dust or dirt being trapped between the connectors that the game cartridge connect too. make sure that this is clean, properly, (not by just blowing into it) my advice is to use a DRY cotton bud or something allong those lines.....hope this helps, if it doesnt get back to me
Jun 01, 2009 | Nintendo DS Lite Console
Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Nov 04, 2008 | Windchaser Stainless Steel Patio Heater...
Bissell power steamer - upright deep cleaner - Does not **** water
If this unit has an onboard heater ( a little red lite in the center of the handle) then most likley it is the problem. You see the heater which is located inside the large portion of the handle has a very small passage that snakes its way throught and heats the water as it passes. The problem is that the water and soap are mixed before the heater which is very very hot and when you turn the unit off and the solution stops moving and hardens in that little passage while the heater cools. To fix this you have to take the handle appart allong with the heater and clean it out. To prevent this in the future make sure to turn the heater off and run just clean water through the unit before you put it away. This unit also has a belt that runs the pump check to see if the belt is in good shape it could be stretched but not broken I would suggest replacing it anyway just to be sure. You can buy the belt allong with other parts for this machine at www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
117 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
