Question about Intuit Quicken 2003 Basic (270902) for PC
Quicken 2003 isn't recognizing my cable modem to access internet
It keeps attempting dialup - which I don't have now.
    President:
  • 2,559 Answers
Open Quicken and go to the menu bar, Click Edit, Click Preferences to open the drop down window and select, Internet Connection Setup and Web Connect. Options will show the different settings that can be customized.
Please Rate This FixYa Solution.
Posted on Jan 23, 2009
I want download usb modem drivers for windows 7, for connecting internet through my lg kg195 mobile
Make sure that you can see the phone's modem in the modem section of device manager(Preset in Control Panel). For airtel connection you have to enter the APN(Access Point name) as "airtelgprs.com" in the PC suite to connect to internet and the dialup number is *99#.
If your pc suite dont have a option for entering the APN then you can manually enter it here-->Go to Control Panel>>Device Manager>>Your phone's modem Properties>>Advance tab>>In Extra Initialization Commands enter this (+CGDCONT=,,"airtelgprs.com") without brackets and create a dialup connection with *99# as dialup number using ur phone's modem, Username n Password field should be blank.
Oct 02, 2010 | Computers & Internet
Hi I have downloaded the pc suite for lg kg 195 but I am not able to connect to the internet. It's not able to establish the dial up connection. Please help me to connect using airtel sim.
Sep 22, 2010 | LG KG110 Cellular Phone
I dont have access to internet am missing the hardwere
Most Internet Service providers do provide the modems necessary to connect to the internet. If you are not using a modem and are using dialup, then you will need to make sure your computer has a dial modem and that you have an active phone line to plug into your computer.
If you would like to use DSL or Cable to connect to the internet, then a call to your ISP will be sufficient and a tech will come to hook up your connection.
Nov 15, 2009 | HP Compaq Presario 6320US (DA202A#ABA) PC...
Please tell me what my modem is for a intel insider windows 2000
A modem that is on its own card in a computer is for dialup access to internet, via telephone lines. Other modems that do the same thing are built in to laptop computers, and always have a regular telephone-type plug on gthe computer. Dialup access is notoriously slow compared to Broadband (Cable/DSL) connections.
Sep 15, 2009 | Intel (272757) Modem
I have a used compacq 530 but do not know what is missing because i cannot get it to hook up to the internet
Possibly if you gave more information .....does it have a network card installed, is the network card "enabled" in the hardware settings, does the network card have correct drivers ? ( no yellow question mark beside it ) Do you have an internet provider and account ? Is your internet high speed or dialup, if it is dialup, do you have a modem installed - with correct drivers ? Is it working - do a modem query to see if it responds ?
If using a network card and cable or DSL internet, is the cable connected from the PC to the cable or dsl modem ? Is the cable or dsl modem plugged in and the power and wan light on ? With the little bit of information you have given, it is not really possible to give an exact answer to what the problem is.
Aug 30, 2009 | HP Compaq d530 SFF PC Desktop
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Setting up an MN700 Base Station with dialup
1. disable all ICS and all Proxy settings on all machines 2. connect the NIC to the MN700 using Port 1 3. set up the MN700 and the wireless connection 4. switch the MN700 to Bridging mode 5. enable ICS on the host computer The basic object is to have the working connection for your dial-up, then set up the base station as an access point only, then share the working connection via ICS through the NIC. Quite similar to having a switch box, but you're going wireless with it. You don't need to feed the MN-700 any of the normal info like your Internet Service Provider's IP/DNS, etc., because your computer already is sharing that info.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Intuit Quicken 2003 Basic (270902) for PC Logo
76 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
