Question about HP (dx973s) (DX973S#ABA) PC Notebook
Need correct computer settings for hp compaq nc6000
Need correct computer configuration for nc6000 having boot problem issues and can only start it up in safe mode. error message IRQ_NOT_LESS_THAN_OR_EQUAL_TO how do i fix this please want my laptop working again.
  • nicholaspenc Jan 23, 2009
    i cant get to system restore as i can only start laptop in safemode and administrators security is full so cannot log on can i get round this first to its running properlt and not in safemode so i can download the drivers needed?
    Novelist:
  • 126 Answers
The first thing is from how many days r u getting the blue screen and if it is from one or two days go to start>all programmes>accessories>system tools>system restore....restore ur system to an earlier date within a week when ur computer was working fine...
if this doesnt work all u need to do is to update and install all the latest drivers in computer and still the problem exist...the problem might be with the cd drive or also cause of the burning software alos...what also u can try is that disconnect the ac adaptor and also the battery and then without the battery and the power cord press and hold down the power button for one minute and then turn on the computer with the power cord and the battery it might help u out......or
That error message generally points to bad or conflicting drivers. Update all your hardware drivers (from the OEM web sites, not Windows Update). Also, for more info go to ...http://www.tweakdatabase.com/idealbb>tweakxp.com</a
Please check Event Viewer for additional information that might help determine the device or driver causing the problem. To do this, click Start>control panel>administrative tools>event viewer>Post any recent Application or System Error event IDs here, or check them at eventid.net.
Cheers
Posted on Jan 23, 2009
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
My hp nc6000 laptop wont boot up i need to reset it to factory setting
When you power on your laptop immediatly after powering on your laptop start pressing F8 key on your laptop keypad, after few seconds Advance boot options menu will appear in front of you in that menu select (repair my computer) option will take you to unother sub menu which will give you an option of load factory image.
Sep 02, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
My hp compaq nc 6000 is running in safe mode, how can i turn this off plz plz help me!!
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 11, 2010 | HP Compaq nc6000 Notebook
Hey can anyone help me, my Compaq nc6000 won't connect to wireless networks it says something about a smart card.
Access the router by means of an ethernet cable and log into the router. Go into the wireless setting of the router and select WPA-AES as the security protocol and select a password. Then go into your wireless settings on the notebook and do the same.
Mar 06, 2010 | HP Compaq nc6000 Notebook
My pc doesn't startup up
I had this problem too but I then downloaded the most recent BIOS driver from the HP web site and that seems to be working. At least it now starts and boots correctly but I still have the problem that it tends to hangs up after a short while.
May 01, 2009 | HP Compaq nc6000 Notebook
I need to reformat my laptop hp compq nc6000,but i don't know how to go about, pls can an expert tell me what to do, pls?
Most HP laptops have a recoverypartition on the HDD. You can start recovery from this by pressing F11 at the HP logo when booting the unit.
Mar 04, 2009 | HP Compaq nc6000 Notebook
Cannot reinstall Windows on my Hp Compaq nc6000
I know I just had the same problem today...when getting into the bios...try using a "multi-bay" boot and have the cd booted first then the hd...That's the only way mine worked to "trick" the system to boot from the cd...it took a few times of stalling after that but with frustration and regathering with patience, it finally worked...you might have problems with the devices not being recognized after it does load unless you have an easy driver set to install from cd...otherwise you might have to manually install them to make them operate correctly. *hint: using the device manager to see any '?s' and reinstall drivers helped me*
Feb 05, 2009 | HP Compaq nc6000 Notebook
Nc6000 will not boot
Sounds like your O/S is corrupt. Can you get to setup? Make sure your hard drive is in the correct boot order.
Jan 13, 2009 | HP Compaq nc6000 Notebook
Screen will not power on
try pluggin an external monitor to the laptop. If you see the screen then your filament ribbon might need repair or replace.
May 06, 2008 | HP Compaq nc6000 Notebook
Boot from dvd
your linux isnt set up to boot use widows inviorment
Dec 29, 2007 | HP Compaq nc6000 Notebook
HP (dx973s) (DX973S#ABA) PC Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
