Question about Pool & Spa
Laing 15kw epr-z spherical motor pump
Electric heatyng-spherical motor pump
I have a 15kw generac genset and it has an "overload remove load" fault which can be cleared from the evolution controller. genset started but shutdown after 5 seconds.
The overload fault is indicating that your connected load is overloading the generator capacity and it's tripping off. Check your connected load (what ever is hooked up that you're trying to power). You need to use an amp meter to verify the amp draw, and also the rated voltage output. If it's low voltage, could be low engine RPM or voltage regulator. high current indicates a problem with load your trying to power, ie-- Motor or other load.
Jan 24, 2018 | Generac Electrical Supplies
How to check n see if heater motor is going bad
Bad motor no air moves. Look on the back of the motor If it is a GE X13 and not running you need a new motor. Many thousands Have failed. Our supplier sends them back for warranty by the pallet load.
Factory replacement warranty is 5 years. You have to pay to have it installed. Out of warranty They cost $560.00 plus tax and installation.
Jan 24, 2014 | Intertherm Heating Cooling System 15kw...
How to fix intertherm mmhb-070a 2006 heater. light on control box is flashing 3 times
That's your fresh air damper control in most mobile homes. At some point the fresh air function is counter productive since it was intended disperse manufacturing fumes. Damper might be stuck or damper motor dead. Wouldn't worry about it.
Sep 24, 2013 | Intertherm Heating Cooling System 15kw...
Intertherms fan stalls
If this fan uses a run capacitor, I'd check it and its wiring and connection first. No problem there ? Then ohm out the motor winding in the fan. If this is a variable speed ECM motor Then you may want to check the module for a burned out thermistor (inrush current limiter) or even check the wiring harness on the motor for tightness. If the thermistor is defective, you can order one from Digi key for less than $2 + postage, adn then solder it in or pay about a grand for a new motor.
Feb 22, 2013 | Intertherm Heating Cooling System 15kw...
Laing circulation pump for Saratoga spa. Put in new pump but now tripping GFCI.
Check your wiring! If it wasn't tripping before and now it is, you have your hot and neutral crossed or neutral and safety ground crossed. You can not draw current via the safety ground, that is what caused the GFCI to trip, it senses current being drawn in that wire.
Sep 29, 2012 | Laing Thermo E10-NSHN1W-19 3/4" Barb...
El carro enciende y trabaja bien en un principio despues de un tiempo se apaga el motor como que no llegara gasolina al motor, y no enciende mas hasta pasado un buen tiempo cuando se enfria el motor...
Hi!!
Por el a?o del vehiculo, casi puedo apostar que es la bomba de la gasolina. Cuando las bombas empiezan a fallar, trabajan por un rato, despues se calientan y dejan de trabajar, al poco tiempo, ya no trabajan para nada. Casi todas las tiendas de auto partes grandes como AutoZone y Checkers prestan herramienta. Consigue un Fuel Pump Pressure tester para que chequees la bomba de la gasolina. Ahi mismo te dicen cual es la presion que debe de tener. La presion se chequea abriendo la llave pero sin arrancar el vehiculo. Aqui esta un diagrama de como se connecta el probador.
Buena Suerte!!
Mar 16, 2011 | 1991 Honda Civic
I have had 2 pump failures with the laing e14ns can the pump be re.built with out the electronics for reliability
No.
Their pump design is propietary and no other manufacturer makes a drive motor that will install on a Laing pump end.
John
Oct 23, 2010 | Laing Thermotech Laing EcoCirc E14NSTN2W10...
I have a Generac 15kW air cooled standby generator. I have replaced the battery the spark plug the air filter the oil filter the oil. It is fueled by propane gas. All it will do is crank. Can you please...
You can check for tanks being turned off and of course if there is fuel in the tanks. If further troublshooting is necessary you should likely ask for assistance.
Sep 21, 2017 | Electrical Supplies
Pool & Spa Logo
20 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
