Question about GE 35GT740 35" TV
GE 35gt740-powering up and shutting off by itself
The problem manifested itself in one day, happening more and more fequently. The tv will turn on for a few seconds and then shut off. I am semi-skilled with electronics but have no repair manual for this unit. Are there any "shoot for the hip" ideas. From what I have read this happens alot with this tv (chassis number ctc203ca5). I have also read about some cold solder joint but don't know where to look to be able to identify this problem. Any help would be appreciated,thanks.
  • 398 Answers
The first step is look for a small coil, L14401, one side connected to the horizontal output transistor and the other side connected to the small horizontal drive transformer. Resolder both pins of the coil and the 4 pins of the drive transformer. Let me know if that cures the problem.
Posted on Jul 08, 2007
Do internal speakers need to be off for external speakers to work
I have found in some instances my external speakers need to be off. Mostly if I use my smart TV on Netflix or Amazon Prime. If you have external speakers attached it is better to turn off internal speakers.
Feb 05, 2013 | GE 35GT740 35" TV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
TV picture won't come on
highvoltage is not coming on
Jul 27, 2009 | GE 35GT740 35" TV
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
GE 35GT740 35" NO SOUND
Did you try turning up the volume on the remote or front panel?
Also, try unplugging the TV from the AC outlet for about 15 seconds to make the TV do a re-set.
Beyond this, there is most likely a failure and the set will require service.
Jerry G.
Apr 10, 2008 | GE 35GT740 35" TV
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Nov 14, 2007 | GE 35GT740 35" TV
Need Replacement Part or Part #
please contact for your parts.
hope this will help
good luck.
Andrew electronics address
In Santa Clarita, CA
www.andrewselectronics.com (800) 274-4666
Oct 16, 2007 | GE 35GT740 35" TV
Pioneer sd532hd5/kuxc/ca powers down on its own
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Nov 09, 2006 | Pioneer PRO-100 TV
GE 35GT740 35" TV Logo
70 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
