Question about Asko 24 in. D3250 Built-in Dishwasher
My asko 3122 dishwasher never heats up
About a week ago we smelled a funny burning smell, and the only thing on was the dishwasher. It was running, and didn't seem or sound faulty.
Then, some days later, we realized that the water was never heating up. I tried the heavy duty cycle, same thing. The dishwasher is about 1 year old. Is this a professional repair job? What likely has happened?
    Scholar:
  • 93 Answers
Sounds as though the element burned out I would suggest you have a qualified technition out to confirm and replace so he\she can inspect the machine and see if there is indeed another fualt,the element can blow for a number of reasons but like a light bulb blowing it is electrical and can go at any time,I would not suggest you attempt the repair by yourself unless you have some sort of experiance with this type of thing.
Posted on Jan 23, 2009
Model d 3250 cycie is finished, dishes are clean the unit continues to make a noise as if it is still running. no water and a slight burning order. very slight
Posted on Jan 09, 2010
DG 50000. Why is there a hot burning smell when it is running?
The motor, the pump, or the heating element could be getting ready to fail.
Oct 03, 2015 | Indesit Dishwashers
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
My asko dishwasher has power to the machine but the lights will not light up. We smelled a burning smell earlier in the day and I think it came from the dishwasher. any ideas?
Yes, this sounds like you r control board has burned out. This is a simpe repair and something you can do yourself to save a lot of money!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we willget the correct part out to you right away along with instructions on how to repair it.
We look forward to working with you!
Ella
Nov 09, 2009 | Asko W6021 Front Load Washer
My dryer stopped working and a burning smell from dryer
this usually means you have a broken belt
the heat is still working but not be ventilated due to a bad belt causing high heat and funny smells
Oct 13, 2009 | Dryers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Dec 17, 2008 | Asko 1375 Dishwasher
Diswasher asko d1716
clean out the food traps in the bottom, assuming the unit has some sort of filter.
then run a cup of bleach in the unit with no dishes. you might need to do this once or twice.
make sure you use fresh bleach.
most bleach dies in strength after only 2 weeks. it will still smell like bleach to some degree, but it will have little effect. most bleach manufacturers add 'scents' to the bleach to hide the degradation characteristics of bleach.
also, you may have a partially blocked air gap.
to determine this, check for water remaining in the bottom of the tub after it drains. left over water will contribute to odor, and negate any sterilization you dishwasher might otherwise try to do.
good luck
mark
Dec 28, 2007 | Asko D1716 Built-in Dishwasher
"rubber burning" smell
check to see if the motor is overheating, the motor could
be getting hot causing the smell, if the motor is'nt overheating, then call the local repair man, we live in miami(florida), and we have a dish washer that keeps on rumbling, we are getting it fixed today, the only big big problem is it seems to draw alot of electricity when in operation, so there's my problem
p.s. is your dishwasher also rumbling and drawing electricity?
shawn henks
miami,fl
Nov 26, 2007 | Asko D1716 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
313 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
