Question about Sony Handycam DCR-IP5E Micro MV Digital Camcorder
Connecting sony dcr-ip5e to HP pavillion vista
I have a new laptop hp pavilion dv4-1038tx which is operating on vista and does not have ilink port or card bus slot to put a firewire card.
I have a firewire cardbus which i use to connect my sony dcr-ip5e to my old laptop which used windows 2000nt. Unfortunately i no longer have this old laptop now.
I would like to know how i can connect to download data from my sony dcr-ip5e on my new laptop which dont have the connection port. I tried with ilink to usb2 cable but my computer doesnt recognize the camcorder
Pls help to point me the right hardware or driver or solution which can solve this problem. Thanks
Regards
Jojo
SOURCE: Camcorder Sony DCR-HC19E not connecting with USB
hi I have the exact same camera,
i had problems connecting it with the firewire connection but not any of the other connections on the camera. I found that it was down to one of the pins on the DV/Ilink connection, one of them had been bent back. i just used a pin to bend it back into shape and it works again
Posted on Feb 16, 2008
  • 73 Answers
SOURCE: drivers!
I THINK SONY WILL LET YOU DOWNLOAD DRIVER FOR FREE AT www.sony.com
Posted on Feb 23, 2008
edo333
  • 55 Answers
SOURCE: Connecting Sony Handycam DCR-HC14E to iMac
There is a great manual here:
http://www.sony.co.uk/support/ShowExternalPage.action?product=DCR-HC14E&supportProductModelName=DCR-HC14E&linkType=manual&isRegistered=false&site=odw_en_GB&pageType=manualPopup&sectiontype=Support&externalUrl=http%3A%2F%2Fpdf.crse.com%2Fmanuals%2F3089850112.pdf&externalLinkType=manual
And in short the I.link is a 1394 port or firewire port
You should be good to go
Posted on May 02, 2008
SOURCE: XP Pro w /firewire not recognizing Sony DCR-TRV730
Try a video card that supports current DirectX. Apparently it has an effect even if you capture without previewing the video. (worked for me, anyway).
Posted on Sep 26, 2008
SOURCE: Compatibility of Sony DCR-HC19E with Windows Vista
a firewire cable works but i have this from sony that might help others with vista as i contacted them direct and they sent me this for vista, http://support.sony-europe.com/dime/downloads/pmb/pmb.aspx?site=odw_en_GB&m=DCR-HC19E.
hope it helps you out
Posted on Nov 07, 2008
I want to connect my HP pavilion notebook dv1000 by firewire
You should be able to get a firewire card to fit you computer. A standard pc card should fit a HP. There are two separate kinds of PC cards. There are the standard and the express versions. Make sure you get the standard version, because express is mostly for Dell. You may want to go to HP and confirm this by looking at the support section for your computer. As far as what type of firewire card, get what you think you will need. There isn't much difference between different brands.
Feb 09, 2010 | HP Pavilion dv1000 Notebook
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
Firewire / iLink transfer failing -HELP please!
Go to camera menu and turn on USB Streaming and try to download movie. Still no joy, iLink port seems broken / faulty.
Jul 02, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
Problem with compatibilty between windows vista
since you're using vista you can connect camcorder to pc uding ilink or firewire cable. usb conection would not work. no dirvers or sofwtare needed, you can use windows movie maker to capture videos. check your computer for any ilink port. it is a different connection from usb. go to www.sonystyle.com and type this model number, vmcil4615, for you to have an idea what firewire cable looks like.
Mar 22, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Jvc problem
I think you can by using the firewire cable, connect it to the the slot indicated by i (for iLink) DV on the camcorder and connect it ot the computer firwire port. A firewire slot is available if a Firewire card is isntalled on your computer. I am in the process of installing a Firewire Card (starting from $15.00 and upwards) hopefully everything works out.
Oct 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
New laptop
any laptop that has an iLink 1394 (firewire on apple computers) port and a DVD burner can do it. Any apple laptop with a superdrive (dvd burner) can do it with iMovie/iDVD, and any windows computer with the i.LINK port and Windows Movie Maker can do the job. I know most (if not all) sony, dell, acer and HP laptops come with the i.LINK port standard, just double check the model when you look at the specs. You'll want at least 1gb of ram (preferably 2GB, especially if you're running windows vista), and the firewire cable to connect the computer to the minidv camera (6 pin to 4 pin if you get an apple computer, 4-4 pin if it's a windows notebook)
Jul 08, 2008 | Computers & Internet
Where is the firewire port?
Confirm that the laptop has a PCMCIA card slot. If so, you can get a Firewire PCMCIA card and communicate at near bus speeds on the laptop. That will be a lot faster than the USB port. Almost any Firewire PCMCIA will work. Just make sure that slot is in your chassis.
May 06, 2017 | Toshiba Satellite R15-829 Tablet PC
Firewire cards
Why do you need to use another firewire card? The firewire port located on the right of the machine between the card reader and USB ports should work fine with most devices. I use mine frequently with a Sony Firewire camcorder and have never had a problem.
May 13, 2008 | HP Pavilion dv6000z Notebook
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Sony Handycam DCR-IP5E Micro MV Digital Camcorder Logo
209 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
