Question about Sanyo Televison & Video
Blown resistors in flat screen
Green light is on, sound is on but no picture
    Top Expert:
  • Sanyo Master
  • 42,979 Answers
Power supply failure. Not just "resistors"
Posted on Jan 13, 2013
  • 187 Answers
SOURCE: black screen
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
  • 187 Answers
SOURCE: Green light but no picture, no sound
  • 187 Answers
SOURCE: rca L32hd31 lcd no picture blank screen.
dave1645
  • 834 Answers
SOURCE: green screen with sound
the T-con board is failing try shopjimmy.com or Topselectronics in Haverhil Ma
Posted on Nov 30, 2009
dave1645
  • 834 Answers
SOURCE: RCA 26" Flat Screen suddenly no picture
The T-con board has failed but i do not think that it is sold seperately you will have to have a tech check it out if your set is just over the warranty i would contact rca they may just pay for it
Posted on Dec 14, 2009
Toshiba 55 55S41U Black screen no back light no picture green power light
have you checked for dry joints or blown capacitors , with a power surge depending what kind voltage or amperage the circuit received it might have even blown screen connect it will certainly fry a lot of components ,have you looked for holes in capacitors ,resistors or burnt tracks between components . that's about all I can think of to check also some power panels have built in fuses to stop surges if you could obtain a circuit diagram that should help you also you could google your query and see if you get any assistance it costs nothing and you could get your TV up and running again . All the best .
Dec 19, 2015 | Toshiba Televison & Video
Dynex dxlcd32 tv not working
No, DX-LCD32 has a known problem with both the inverter and the CCFL lamps or, to be precise, the connections of those lamps, which tend to rust, desolder and break contact.
Doesn't mean that's the problem your TV has, but I am just noting that it is not the main board they are known to have a big problem with.
And the symptoms you describe would rather suggest a functioning main board than a bad one.
Lack of sound is probably simply because you're not having the TV on the right AV input.
Sep 30, 2012 | Dynex Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Philips 37pf9975/12 wont switch on
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Jan 09, 2009 | Philips 37PF9975 37 in. HD-Ready Plasma...
Techwood twp 4205 screen doesnt knock on but sound comesout of speakers all green lights are on but no picture
quick easy fix.
white block style ceramic resistors (2 of) on power board.
go to rs components online
part number 199-7696. pennies each.
replace both resistors.
Done.
May 03, 2008 | Sylvania 6626LG 26 in. LCD Television
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
