Question about Garden
Need a diagram for throttle linkages for a toro 724 snowblower
jgwhomeequip
  • 1902 Answers
SOURCE: toro 724 snowblower won't start
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Posted on Feb 09, 2009
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 6982 Answers
SOURCE: missing factory throttle linkages on 1990 YJ jeep. Need Diagram
Go to any scrapyard and you can get the entire setup for next to nothing...and you can see how it's hooked up!!!
Posted on Jul 07, 2009
rycgl
  • 1545 Answers
SOURCE: toro recycler rear bagger linkage set-up to
Hopefully, this will clarify it..
http://small-engines.com/bsgovernors.html
Posted on Sep 15, 2010
No spark on Tora 724 snowblower, mod. 38050 Ser. 1004915, new pts set at 0.020, emptied old gas, add new gas, condenser, plug, new coil. is there a grounding problem that I missed? Air gap setting behine...
Ground is only for shutting of engine if it not hooked up wont turn off. Take flywheel off and look at magnet. Make sure it has not moved meaning they are glued in place and wont fall off. Give it a wiggle and see if it slides. If it does pull magnet off and re-glue in place. You will see mark on inside where it was originally.
Feb 19, 2015 | Toro Power Max 726 OE Snowblower - 37771
Throttle linkage diagram for toro 22035
This is the site I use frequently. There is a blowup diagram of the linkage. http://www.partstree.com/parts/?lc=Toro+Consumer&mn=22035
Dec 13, 2014 | Toro Garden
Governor linkage on toro snowthrower model#38415
If I cross reference the engine correctly it is a TEC HSK 850 so the follow service manual should be what you need.
Nov 03, 2014 | Garden
My snowblower does not seem to run at full speed. Barely throws snow recently. Any adjustments I can make?
There is a spring attached to the throttle linkage. At the other end is an arm that the spring attaches to. Bend the arm so that the spring is tighter and it will throttle up higher under a load. Don't go too far or you will take a chance of blowing the engine. Best to use a rpm tester and set it to factory specs.
Feb 22, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro rider 16-38 HXL when I start it revs at FULL speed and sounds like it will blow up. I slow it down with choke all other linkage seems to be in place properly- Is there a trick to fixing?
Three options:
1. The carburetor throttle plate (closest to the engine is stuck); clean it with gumout and work it back and forth
2. the linkage is hooked in the wrong hole ; check the wear pattern on the throttle shaft plate to see if it is in the wrong hole.
3. The govenor arm or gear is not adjusted properly; loosten the govenor arm, push the throttle plate of the carburetor all the way closed. push the govenor arm the same direction all the way until it bottoms out. tighten the arm clamp. Test again
I recommend getting a manual or at least a free parts diagram from a local shop like www.arcolawn.com
Good luck
Joe
please vote me up if the fix was good.
Dec 29, 2010 | Toro Lawn Mower With Toro Power Tools
May 19, 2009 | Garden
Toro 724 snowblower won't start
Feb 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
