Question about Dell Inspiron 1501 Notebook
How to replace a dell e1501 inverter - Dell Inspiron 1501 Notebook
  • Dell Master
  • 7,627 Answers
This will give you the idea: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Posted on Jan 13, 2013
I have a dell laptop an the pixels r goinjg out i dnt want to buy a new computer. if u press the screen it works otherwise it freezes the screen then the screen is covered in different colored lines. im...
Hi matt d224...
.I included a couple of links to some parts for the D420
There is one test to determine if it is the screen causing the problem or maybe the lcd converter.
Plug an external monitor into your laptop and see if the picture is good...if it is then replace the lcd screen.
If there is still no picture then the problem is probably the lcd inverter needs replacement
Please take time to rate me
Dell Latitude D420 replacment lcd screen:
http://www.laptopscreen.com/English/model/Dell/LATITUDE~D420/
Lcd Inverter replacment:
http://www.yallstore.com/laptop-lcd-inverter-replacement-for-dell-latitude-d420-141-p-1275.html
Youtube video "How to replace a Dell Computer screen";
http://www.youtube.com/watch?v=P7LVbOT5DnQ
How to replace a lcd inverter...this one is for a 630, but your will be the same:
http://www.youtube.com/watch?v=_ILAkFWp3gQ
Sep 11, 2011 | Dell Latitude D420 (DELLD420) PC Notebook
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
Dell d410 lcd display is dim
may need an inverter or replacement lcd if the bulb in the lcd is damaged. The Good neews is that 98% otf the time a display ges dim tth inverter is the cause and its abit easy to replace.
heres the inverter
http://cgi.ebay.com/Dell-Latitude-D410-Inverter-Board-12-1-LCD-IV11176T-LF-/370391713650?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item563d110772
Jun 19, 2010 | Dell Latitude D410 Notebook
Dell Vostro 1500 Repair manual and parts for backlight and inverter
You cannot replace the backlight. It is incorporated into the lcd panel and not available as a separate part. The inverter board is very easy to replace. It is located right behind the dell logo at the bottom centre of the display panel. Remove the screws on the front of the lcd bezel (under the rubber pads) and the inverter board is right there. Call 1-800-www-dell or look on ebay. Hope it's only the inverter board, as a new lcd panel is $350+. If the display is dead you can still use the laptop by connecting an external monitor to it.
Hope this helps!....let me know how you make out.
Dec 12, 2009 | Dell Vostro 1500 Notebook
Dell Inspiron 6000 Laptop Screen has Faint Image
It's a faulty backlight (screen).
Replace screen (same dell part number) with inverter, otherwise screen can be dark.
Here is how Dell part number looks (green):
Aug 19, 2009 | Dell Inspiron 6000 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501 Notebook Logo
19 people viewed this question
Alun Cox
