Question about Frigidaire Washing Machines
Frigidaire Model LTF 530FSO
Washer will not spin.
  • 1294 Answers
SOURCE: will not balance
The front 2 legs should be screwed in completely, and locked with the check nut. (the check nut is at the upper end of the bolt, and is a loose nut) This means the machine is lowest in the front. If you find any shake (try with both your hands) adjust accordingly, & lock with the inner check nut. Normally the machine adjusts itself if the weight is un-balanced; but it cannot do anything if the legs are uneven.
There could be some spring or shock-absorber come loose inside the machine. Plug off the wall, remove panel behind & check. If you could remove the top to check fine. Also find out the actual capacity of the machine - look user's manual (a book which is seldom read), it would be good to actually weigh your dry laundry to have an idea. Would be nice if you rate me pl. Good luck.
Posted on Dec 13, 2007
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: washer won't spin
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Posted on Jan 19, 2009
canbruce75
  • 1776 Answers
SOURCE: washer wont spin
If the unit will pump, but not spin, check out the following:
* Door latch switch- inside the washer main housing near the door frame. Check switch with an ohm meter to determine if it is good or bad.
* Belts
* The drive motor.
*The spin bearing or basket drive may be seized.
The most likely problem is the door switch. Hope this helped. Good luck.
Posted on Jul 16, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Posted on Nov 06, 2009
In search of a manual
Hi Buck, I am happy to assist you!
I see you are looking for the manual of your Frigidaire washer, LTF2140ES2. I have successfully located the Owner's Guide. I hope this information helps to some degree. If you need further help, please feel free to reconnect. Thank you! - Z
Aug 25, 2014 | Frigidaire Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
I have a Frigidaire Affinity LTF 8000 washer that will not complete the spin cycle. Items are still completely wet when wash is "finished". Even in "spin only" mode, I can hear the...
If you cant access the drain pump from the front then you will need to pull the machine out and tilt it back as far as possible safely, this will allow you access to the bottom of the machine and the drain pump. You will need a basin to catch any water that will come out when you remove the drain pump. The pump should only be held in by 1 or 2 screws and pulls or twists off. If the pump is clear then you will need to remove the pipe that goes from the pump to the drum to check for blocks, commonly a sock is blocking it. hope this helps
Feb 23, 2011 | Frigidaire Affinity ATF8000FE
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Sep 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer wont spin
* Belts
* The drive motor.
Jul 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
