Kenmore elite oasis 110.27062600 unbalanced
Continually becomes unbalanced
BIKER T
  • 909 Answers
SOURCE: Kenmore Oasis becomes unbalanced all the time
Its a tricky repair. there is a spring that sits on the base of the motor. You need to remove the pulley and plastic gears to gain access. This spring is slipping causing drum not to spin correctly. Remove it and clean properly with solvent . If broken replace. Reinstall and retry.
Posted on Sep 21, 2009
jan mczeal
  • 632 Answers
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Posted on Jan 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: UL ( unbalanced load ) signal appears, washer will not spin
Re-balance the load, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Posted on Sep 26, 2010
Why dose my kenmore elit oasis he washer keep geting unbalanced with or with out a load in it
Possiable it has a broken yoke on the inner drum, Mine broke completely off. Lucky it was covered by Sears warrenty. Cost is over$1,000 to repair with out warrenty.This is a common problem with He Washers..
Sep 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis starting to show "UL" and immediately stopped working. How do I fix this issue?
UL = Unbalanced Load
re-distribute the clothes and re-try.
Aug 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Sep 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite washing machine always has an unbalanced indicator, even if i run it empty.
Check the balance load sensor.
Aug 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
