Question about Canon PIXMA MP460 All-In-One InkJet Printer
Can't print in color on canon mp480
Set it to black ink only and now can't remember how to turn color back on. I am on an Apple computer.
    Problem Solver:
  • 8 Answers
When you go to print theres and option for all black ink. Turn it off by pretending to press print go to that section and unmark the box for black ink/ print in black and white.
Posted on Jan 13, 2013
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
rulds2008
  • 3866 Answers
SOURCE: canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
Posted on May 26, 2010
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
Canon iP6600D printer keep printing in Blak ink only
1st option, set the default profile in the printer properties. if it doesnt work. this will change all the settings that you might missed to check to go back to factory setings. also, check if your color cartridge is ok and with enough ink and not dis abled
2nd option, run any 3rd party software that can fix some windows system files or something like that. try to scan pc for viruses
3rd option, reformat your pc. maybe windows files that allows your printer to work are having problems or corrupted, base on the thing that you mentioned that it goes back to the grayscale settings
May 27, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Won't print in color
How long have you had color ink cartridge in the printer for? Have you triple checked you have set the settings to print color? If it still persist then the possibilities are your ink color cartridge is out of ink? have you made sure it's installed properly?
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 14, 2012 | Canon Pixma MP480 All-In-One InkJet...
Only want to have the black ink installed in my Canon Mp480
You Can Press the Cancel and The Power Button At the Same Time...
And wait for around 5sec. It will Turn Off. And Again On It.
It will work without the Color Ink!!!
Sep 10, 2012 | Canon Pixma MP480 All-In-One InkJet...
How do you change ink cartridges in a Canon Pixma MP480 printer?
I cannot believe no-one has answered this one but you just lift the platen/glass top unit from the front edge (the hinge is at the back) and when the carriage slides into view, flip the levers over the print cartridges up and lift the cartridges out. It should be in your manual but it's very intuitive and someone has probably shown you by now anyway. Hope you are up and running already.
Nov 24, 2011 | Canon Pixma MP480 All-In-One InkJet...
Can i use pg-40 ink for my canon mp480
Sorry you can't use PG-40 on MP480. Canon MP480 printer takes only Canon PG-510 Black Ink Cartridge, Canon CL-511 Colour Ink Cartridge or Canon CL513 Colour Ink Cartridge (this one is high yield colour cartridge).
Feb 02, 2011 | Canon Pixma MP480 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
71 people viewed this question
old marine
old marine
