Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Leaking aqua stop on Miele G646 SC plus dishwasher
The aqua stop fitting leaks. A new one costs 134 pounds, is it easy to fit? Can it be replaced with a standard 5 pound fill hose?
2 Suggested Answers
  • 230 Answers
SOURCE: Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Posted on Sep 06, 2012
Sep 06, 2012 | Miele Dishwashers
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
I have just bought a miele 5100 dishwasher, my husband connected it, but the inlet hose connection that goes to the water supply, which has a large plastic piece on it is leaking, you can click it open but...
the big box on the tap end is called the aqua stop fitting. If it leaks around the tread make sure there is a washer in the big nut that screwas onto the tap. The tap might be old and not true on the fase. You could try some thread seal tape on the tap thread. good luck
Feb 10, 2011 | Miele Dishwashers
I have a Miele dishwasher that has a small leak by the intake hose which is connected to the water supply. How can this part be repaired or must it be replaced
The inlet hose to a miele dishwasher has a box on the end of it, and a brass garden hose thread fitting on the end of it. Inside this brass fitting is a black rubber garden hose washer. I have never seen the hose break. Are you sure it is not leaking from the washer or maybe missing the washer altogether? It is expensive to get the hose replaced.. 200+ for the hose and 175 for the service call. the dishwasher has to come out and be turned on its side to replace it.
Nov 21, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hi, Our Miele G611SC plus is making a high pitched noise for about 1 minute when (I think) it is on the rinse cycle. When it then changes to the next cycle, the high pitched noise stops. We got the unit...
Hey Berni,
I've been having the same problem for quite sometime with my Touchtronic G 892 SC. It goes away if I open up the cabinet under the sink and wiggle the water inlet hose where it's connected to the dishwasher's "backflow" water inlet. I'm getting ready to disconnect the fitting and see if there's lime (or some other type) of buildup in the filter screen. I don't know what else it could be. I'll try to follow-up when finished with this task.
Nov 02, 2010 | Miele 18 in. G611SC Plus Slim-Line...
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
I HAVE A MIELE G646 SC DISH WASHER AND IT KEEPS LEAKING WATER INTO THE LOWER TRAY AND CUTTING OUT BECAUSE THE FLOOD SYSTEM KICKS IN.I HAVE THE MACHINE IN THE GARAGE WORKING UP ON TWO WORK MATE WITH THE...
have you made sure the water sofener filler neck locknut is tight to the bottom of the dishwasher?
i have had experience with one machine where spilled salt was not rinsed away after the softener was filled and this corroded a very small pin ***** sized hole near the filler neck
Mar 25, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
63 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
