Question about Tools & Hardware - Others
Planer molder Model 306-233751
Need a manual for this craftsman planer molder
Need a manual for Craftsman Contractor series 12 1/2 Planer #351.23383
Go to the Sears Parts Direct web site and search for the Planer model number. I got two results, the second one had a link for the manual. Here is a direct link: 351233831 CRAFTSMAN 12 1 2 PLANER MOLDER Manual
Jul 06, 2014 | Craftsman 12 amp 12-1/2" Bench Planer...
The infeed roller is uneven and it snipes the boards
Sniping is common, try feeding waste stock in before or after your good wood, whichever end is getting sniped. The planer will not notice the end of your wood, and cut it flat.
Oct 03, 2013 | Powermatic 1120003 PM15 Planer/Molder
Where do i find molder knifes
Moulder knife blades, are usually available for a particular machine only fromm the manufacturer. I suppose a machine shop could make some up, but it would too expensive IMO.
May 03, 2010 | Wmh Tool Group Jet 13" Planer Molder
I have a Jet planer 15 and the wood gets stuck
I think you are trying to remove too much wood in one pass.Don't cut so deep and see if it will feed thru then. hope this helps you
Jan 17, 2010 | Wmh Tool Group Jet 13" Planer Molder
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Craftsman planer joiner
go to sears.com and order the manual and/or part that u need.
May 13, 2009 | Masonry Tools
How to make crown molding with a jet 13" planer /molder
You may want to go to the Forum at OWW (Old WoodWorkers.com). What your attempting to do requires several Passes. I usually Rough out BOTH Face & Bevel, then make 2 more cuts each, to get to the Finished dimensions. I usually start with a Face Cut 1st, leaving some Flats for Square then do the Bevel Cuts to Desired dimension, then back to the Face, & take it down to where the Finished product is where I want it.
Dec 22, 2008 | Wmh Tool Group Jet 13" Planer Molder
Tools & Hardware - Others Logo
194 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
