Question about Kenwood CD-203 5-Disc CD Changer
Kenwood cd-203 5 cd humming sound
The humming sound can be heard thru the speakers,
  • 338 Answers
Check your RCA cables to make sure that they are not dirty, tarnished or not completely plugged in. Also, try switching to different (working!) RCA cables to see if that fixes the noise problem. Good luck!
Posted on Jan 20, 2013
2 Suggested Answers
gokomets
  • 120 Answers
SOURCE: Kenwood CD-203 5-Disc CD Changer will not play CDs
The laser might be the culpert, be sure its clean by using a swab and a alcohol. If the laser is needed
it could cost approx $75 unless their using a Sony
which might be cheaper!
Posted on Apr 17, 2010
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Subwoofers repair
It may be a Ground problem, Capacitor, or your audio receiver.
try with different receiver and try your receiver with another sub.
Jan 21, 2014 | Car Audio & Video
Cd player makes humming sound
You may have a bad RCA cable connecting it to them receiver/amp. Another possibility is that the power to the CD Player (If not polarized) need to be flipped. Good luck and be careful!
Jan 13, 2013 | Kenwood CD-203 5-Disc CD Changer
When switched on a humming sound comes out of all speakers,no audio can be heared when a cd is played.
check all jack plugs are in the correct places and speaker connection wires too.try turning your tuner on to test the speakers that way for sound,if sound is heard through the speakers it could be a cd malfunction.if nothing works contact your dealer.
Sep 03, 2011 | Eltax Nova Theater System
How to connect the entire system kenwood sorrender receiver vr-357 stereo double cassette deck ct-203 multiple cd player cd-203
Find the manuals and read.
You might find them at the manufacturer's support sites, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
Aug 14, 2011 | Kenwood VR-357
Playing cd's no sound from the speakers when I have the cd/dvd option selected. When I put the reciever on I can hear dead air coming thru the speakers but not when I have the cd switch selected....
You need to find the manual and/or read and understand every indicator and evaluate how it affects the sound. Use a medium volume setting while troubleshooting.Check connections.
Start with the basics. Speaker test ok? FM ok. Digital sources assigned yada yada.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-8060-Receivers-manual/id/480ci254/t/2/
Jun 30, 2011 | Kenwood VR-8060 6.1 Channels Receiver
Kenwood CD-203 5-Disc CD Changer will not play CDs. It powers up and recognizes a CD within the slot, but it does not read the disc to begin playing.
Apr 17, 2010 | Kenwood CD-203 5-Disc CD Changer
NO SOUND COME FROM INSIDE SPEAKERS ONLY LOWS PLAYING THRU SUBS
try wiring the speakers up directly to the stereo instead of the wires that are already in the car, if it doesnt work then give up
Jul 05, 2008 | Kenwood KDC-2025 CD Player
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Kenwood CD-203 5-Disc CD Changer Logo
76 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
